Elec Problem 73 Toyota Coaster
Submitted: Thursday, Dec 30, 2010 at 22:56
ThreadID: 83334 Views:4294 Replies:4 FollowUps:5
Slight problem I am hoping someone can help me with while installing a battery bank in my old girl she seems to have blown a fuse but all fuses in fuse box are intact power is at battery but nothing there to start her or power on the on console is there another bank of fuses somewhere??
help!
Reply By: Farmboywa - Thursday, Dec 30, 2010 at 23:31
G'day wandering drew, I had a problem like this once, and it turned out the battery lead had parted company from the battery clamp inside the cable insulation.
AnswerID: 440246
Reply By: Member - Keith P (NSW) - Thursday, Dec 30, 2010 at 23:45
Also a lot of these older vehicles have a fusible link in the wiring between battery and main harness. It looks like a short piece of wire with a terminal on each end of it..sometimes there is more than one.
Dont use any old wire to substitute it ...replace it with the correct stuff. Should be available at most auto leccys ...or just go genuine.
HTH.
Cheers Keith
AnswerID: 440247
Follow Up By: 3GoBush - Friday, Dec 31, 2010 at 00:03
I'm with you on the fusible link.
FollowupID: 712143
Follow Up By: wandering drew - Friday, Dec 31, 2010 at 00:21
Now that makes sense and would explain why its all so dead Thanks for that!
FollowupID: 712145
Follow Up By: ross - Friday, Dec 31, 2010 at 18:40
See if you can find a remnant of the old fuse wire.It will help to find the correct amperage.
My landcruiser(which are similar in this respect) had the same problem.They all seem to go when they get old if something else
doesnt blow them
FollowupID: 712215
Reply By: wandering drew - Friday, Dec 31, 2010 at 00:27
Might add to my original post here also I have put in a Dual battery system on my old girl and The problem I was addressing before whatever went was finding out how to disengage the interior lights from the starting battery and have them connected to the 2nd battery bank has anyone done this to a coaster of my age? I was thinking to remove the original fuse wire and replace it with a new one from the 2nd battery
AnswerID: 440255
Follow Up By: 3GoBush - Friday, Dec 31, 2010 at 00:33
Perhaps you may have set the duel battery up in a 24 volt set up as apposed to a 12 volt set up, therefore you may have blown all the fuses.
FollowupID: 712147
Follow Up By: Member - Keith P (NSW) - Friday, Dec 31, 2010 at 22:42
something else to consider....what about replacing the interior lights with L.E.D.s??
there are kits available now (from Jaycar..to name one) that will fit in the original lights..so leave your wiring as it was and install LEDs. Use bugger all power and last a lot longer. I have done all the interior lights in my Patrol now....and when we are camping the tailgate doors are just left open while ever we are up ..as the fridge is in the back. Have been left on for hours and hours...and no probs firing up the ole diesel next morning
Just a Thort.
HTH.
Cheers Keith
FollowupID: 712231
Reply By: roberttbruce - Friday, Dec 31, 2010 at 10:07
my coaster is a bit younger than yours but still in the same vintage...
i had the same issue a few weeks agio - ended up replacing every fuse whcih sorted it..
AnswerID: 440278
