Dual Battery Isolator- Redarc, Matson or Projecta
Submitted: Wednesday, Jan 05, 2011 at 01:25
ThreadID: 83443 Views:20937 Replies:9 FollowUps:4
Howdy all, i am in the process of chasing down the gear for my dual battery system.
I wanna know if the Redarc 100A isolator is still regarded as a good unit. I fitted one about 3 years ago to another car and it did well, but since then have read a couple of threads about some failing etc.
I like the price of that unit, and also the jump start feature. Plus i know i can fit it in my engine bay with a bracket that suits my car, making the job of fitting very easy.
I nticed on Ebay that the Matson and Projecta 150A isolators are around the same price too though, but just wanted to know if the Redarc was still a favourite. When i purchased it last time it was the pick of the crop.
Have things changed?
Will be wiring it all myself, as its the only way to get things done properly around here.
Reply By: Member - Howard P (WA) - Wednesday, Jan 05, 2011 at 03:17
Hi Muntoo,
I have had the Redarc fitted to my 100 series for a couple of years now, and no problems what so ever. Not too sure about about the other types you mention but the "jump start feature" on the Redarc is a really good feature as my start batteries (after 4 or so years failed the other day) and it made starting the vehicle quite easy, until I got home and had time to replace the start batteries.
Howard
AnswerID: 440748
Reply By: Peter_n_Margaret - Wednesday, Jan 05, 2011 at 06:11
I chose a 2 way, 200A RedArc because it was locally made in Adelaide and there was good local back-up (which I have never needed).
OKA106 Motorhome.
AnswerID: 440750
Follow Up By: Kanga1 - Wednesday, Jan 05, 2011 at 11:56
X 2 Redarc for me. Cheers, Kanga.
FollowupID: 712654
Reply By: Mick O - Wednesday, Jan 05, 2011 at 07:06
Hey Muntoo,
I'm using the 200A isolator as well as the BCDC1220 DC charger. Found them to be very good and as you'll see from quite a few threads on the forum, their customer service is very good.
My review of Redarc products used.
Cheers Mick
AnswerID: 440752
Reply By: nick b - Wednesday, Jan 05, 2011 at 08:12
i to have one no problems ,ARB here are selling & recomending them . "kis"
regard wiring , if you want a good job do it your self .
AnswerID: 440755
Reply By: dereki - Wednesday, Jan 05, 2011 at 08:23
They are a very popular unit, so hearing about a few failures is probably ok percentage wise.
D
AnswerID: 440757
Reply By: Ray - Wednesday, Jan 05, 2011 at 09:25
I have had a "dual" battery system for years. My second batteries are on the draw bar of my caravan and therefore not permanently on line. All I use is a standard 150 amp relay energised by the car's ignition. Works fine and cheep to install. The positive line is fused either end.
AnswerID: 440761
Follow Up By: Member - Bruce C (NSW) - Thursday, Jan 06, 2011 at 10:48
I agree with that.
I went from a Redark back to a simple solenoid system which is operated from the ign and it works best of all IMHO. No ign, no connection to car battery, turn on ign to start and second battery adds to start battery. Never a problem.
Cheers, Bruce.
FollowupID: 712751
Reply By: Gronk - Wednesday, Jan 05, 2011 at 14:16
Traxide......no affiliation, but check out their prices and features !!
AnswerID: 440783
Reply By: ABR - SIDEWINDER - Wednesday, Jan 05, 2011 at 17:25
Hi Muntoo
What do you drive and where is 'around here' ?
Derek from ABR
AnswerID: 440792
Follow Up By: Muntoo - Wednesday, Jan 05, 2011 at 18:36
I drive a BT50 and around here is Broome WA.
FollowupID: 712682
Follow Up By: ABR - SIDEWINDER - Wednesday, Jan 05, 2011 at 19:50
Yes that would be a DIY location. You should have space for a 10 inch battery passenger side in front of the air filter.
The BT50 alternator voltage will not be a problem for any of the VSR type isolators.
FollowupID: 712686
Reply By: Muntoo - Wednesday, Jan 05, 2011 at 18:38
Excellent, thanks everybody.
Looks like Redarc it is again.
I can get one for $88 delivered off Ebay. I think thats a very good price.
I reckon i can get the full system including a tray, wiring and battery for under $500.
Im happy with that.
AnswerID: 440797
