solar regulator.
Submitted: Saturday, Jan 08, 2011 at 15:47
ThreadID: 83519 Views:3737 Replies:2 FollowUps:5
G,Day everyone. question for the solar experts. santa gave a 80W fold out powertech zm9130 solar kit. When hooked up to 12.v aux battery in full sun volt meter was going from 12V to 13V rapidly. so I hooked up multi meter in series on 10 amp. and another multi meter paralel on volts. In part sun all good steady 2 amp and 13 v , Then in full sun amps are going from 0 to 4 and volts 12.5 to13.5 like a mad thing. I suspect the regulator is faulty. can anybody help with problem. many thanks in advance an have a safe year.
Reply By: Mandrake's Solar Power- Saturday, Jan 08, 2011 at 16:01
Lucky Macca but Santa may have overspent .. LOL
The reg is probably in FLOAT mode and will be pulsing microsecond bursts of low voltage high current at your battery - This is normal ..
If you need to test it further then run a decent heavy load off the battery and see if the input steadies to 4 - 4.5 Amps .. Run an Airpump or 12V vacuum cleaner - something that uses about 10-15 Amps ...
I think you'll find it is working as it should ..
However if you need it tested and you're close by - bring it over ..
Steve
AnswerID: 441118
Follow Up By: dbish - Saturday, Jan 08, 2011 at 17:58
Hate to say this but digital meters are useless on varying voltage. Use an analogue meter when dealing with varying voltages. You may find it is actualy going to 14V then droping back then upto 14V again & thats fine for that type of regulator. This will only happen when the battery is near fully charged.
FollowupID: 713081
Reply By: paulnsw - Sunday, Jan 09, 2011 at 08:53
The regulator is working as designed. The regulator is pulsing the battery and that is how modern solar regualtors work.
Don't worry about the smart ass comments from resellers with low quality silicon in the panels and glass. Your Powertech panel is a good panel with good quality silicone and iron free glass. Your Powertech panel also includes a *REAL* warranty and is a good value for money product.
AnswerID: 441200
Follow Up By: Macca44 - Sunday, Jan 09, 2011 at 10:59
First of all thanks for all advice. Looks like all is good. ran the battery down over night to 11.5v Hooked up the solar panel this morning in full sun reading 4.5 amp and steady and 12.5 v . so must be ok. Also on the regulator is a short wire with a bulb on the end marked temp on the reg terminal, what has this to do with things. many thanks again.
FollowupID: 713180
Follow Up By: paulnsw - Sunday, Jan 09, 2011 at 11:51
The short wire with the bulb is a temperature sensor.
If you have the expertise or can find somebody to do the job properly and correctly for you, the regulator is much better close to the battery rather than on the back of the solar panel.
The temperature sensor will then sense the correct temperature and not the heat from the back of the solar panel and you will have the correct voltage not having any voltage loss from the regulator on the back of the panel to the battery. Temperature plays a big part in the charging a battery correctly and sensing the correct temperature to ensure the battery is not over charged or under charged is really important.
FollowupID: 713196
http://www.jaycar.com.au/ShowLargephoto.asp?id=14652&PRODNAME=80W Portable Fold-Up Solar Panel&IMAGE=3
FollowupID: 713198
Follow Up By: paulnsw - Sunday, Jan 09, 2011 at 11:53
Correct link to picture here.
FollowupID: 713199
