SIDE 4WD SHADE AWNING
Submitted: Monday, Jan 10, 2011 at 21:32
blackmax
I am interested in buying an awning I can attach to the left side of my Toyota Landcruiser. I think I would like a spring loaded return unit but am open to suggestions from those that have products they are happy with.
Look forward to advice on what brand & model to buy and where available?
Thanks, Ken
Reply By: Member - Mark G Gulmarrad - Monday, Jan 10, 2011 at 21:39
Ken
i got
mine through a guy in
brisbane...Aussie outdoor direct. great to deal with and have been very impressed /happy with
mine and 100% recommend it,cheers.
441425
Follow Up By: blackmax - Tuesday, Jan 11, 2011 at 09:30
G'day Mark,
Great info, thanks.
KEN
713530
Reply By: Ruffy-Dan - Monday, Jan 10, 2011 at 21:53
Alot of the spring loaded, self returning ones end up being manually wind up ones.. Don't expect the cheaper ones to stay retractable. Not saying don't get one, just don't expect too much.
Dan
441427
Follow Up By: Member - Mark G Gulmarrad - Monday, Jan 10, 2011 at 21:55
Dan
maintanance is the key to most things,i give
mine a shot of innox regulary and no probs yet in the couple of years
mine has been fitted.
touches wood :-)
713499
Reply By: Member - Stephen L (Clare SA) - Monday, Jan 10, 2011 at 22:39
Hi Ken
Years ago we had a canvas awning made up that slid into a rope rail on the side of the pack rack. Took quite some time to slide on and set up, but it was good. Seeing that we do not take a pack rack any more, it was back to the drawing board. We happened to be at the
Adelaide 4X4 Show and immediately saw what we were after, a Black Widow awning that would attach to the cross bars on the rook. It has its own protective cover and is as simple as unzipping the cover, undo 3 straps and unroll. You then put the 2 side poles in place and it is all set up. When it is time to roll it up, it is just reverse the set up. If I said it takes two minutes, I would be wrong as it usually takes less than a minute.
Here are a few pictures of our old original unit ant the Black Widow.
Image Could Not Be Found
Image Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
441434
Follow Up By: blackmax - Tuesday, Jan 11, 2011 at 09:29
Stephen,
Thanks for the photos and info.
KEN
713529
Reply By: Member - Mfewster(SA) - Tuesday, Jan 11, 2011 at 07:35
IMHO, side shades are overpriced and it is easy to make one of your own that will be considerable stronger, cheaper and better designed to give a more versatile shelter. Quite a few people have now copied my design. Happy to provide details if you want to explore making your own.
441443
Follow Up By: blackmax - Tuesday, Jan 11, 2011 at 09:35
G'day Mfewster,
I would love to get the info and details of your self designed product, it can be sent to me via email - blackmax11@pacific.net.au
Look forward to seeing it.
KEN
713531
Follow Up By: Member - Mark G Gulmarrad - Tuesday, Jan 11, 2011 at 09:37
Mfewster
would be interesting to see your design,do you have any pics you could put up on the
forum?
cheeers mate.
713532
Follow Up By: Member - Mfewster(SA) - Tuesday, Jan 11, 2011 at 10:06
Mark. Unfortunately, the photos I have aren't the best. I keep the awning attached to my roofrack and that is currently off the vehicle and up in the roof of my garage. Next time I am using the roofrack I will set the whole thing up and get clearer pictures. Meanwhile, I have a couple of sketches and a description of what I did that I am happy to send to anyone who wants them The main pont is to make a design that gives more shade for much the same canvas area. it does this by having a flap like the side of an a frame tent and poles that can be used at different heights. It can also be used like an a frame tent.
713535
Follow Up By: Member - Mark G Gulmarrad - Tuesday, Jan 11, 2011 at 10:13
Mfewster
yeah no worries mate.....might be a good little business you could get going there perhaps?
cheers.
713537
Follow Up By: Member - Michael P (QLD) - Tuesday, Jan 11, 2011 at 14:33
Mark,
This is basically a25mm sq tube with a telescopic 20 mm sq tube as an extention u bolted onto the roof rack .I have made it so as I can cover over the front door or to go past the rear door.Very easy to make & pretty simple to put up If you (or others ) want details happy to oblige.
Mike.
713565
Reply By: Member - Phil B (WA) - Tuesday, Jan 11, 2011 at 09:53
Hi Ken
I went for a Fiamma wind out job that are used on caravans and campers. After fiddling with roll out models an trying single handedly to set them and more importantly pack them away - I looked around for something else.
Go to
http://www.camec.com.au/images/brochures%20pdf/FIAMMA%20AWNINGS%202P.pdf
Are they strong - yes. I saw two of them on the CSR in 2009 and no probs were experienced. I have used
mine only a few times and am delighted. Sadly l haven't any photos.
Would l ever buy another should I need to do so - in a heart beat.
The only down side is they aren't cheap.
441457
Follow Up By: blackmax - Tuesday, Jan 11, 2011 at 10:22
G'day Phil,
Thanks will look at the product.
KEN
713538
Reply By: tg123 - Tuesday, Jan 11, 2011 at 10:04
I've got the ARB awning fitted to 2 heavy duty Rhino cross bars - not an auto retract but rolling it up takes about 30 seconds. Advantages - quite cheap, sturdy enough for how and where I use it and quite easy to erect and pack up. Easier with two people but one is OK provided it isn't too breezy. Have permanently attached a couple of sprung guys and ALWAYS peg it down!!
Downside - it probably won't last as long as the expensive ones, but then I can always buy another one and still be ahead!
TG
441461
Follow Up By: blackmax - Tuesday, Jan 11, 2011 at 10:23
TG,
Have an ARB
shop not far away, will call by and have a geek.
KEN
713539
Reply By: Member - IdahOz - Tuesday, Jan 11, 2011 at 12:55
We are very happy with our foxwing and have had no problems with it. We have it on the L side of our trailer and it opens around to cover the front where we have the fridge box as
well as the side for our kitchen. We are getting an add on panel that can be moved around to provide even more shade.
441474
Follow Up By: blackmax - Tuesday, Jan 11, 2011 at 14:14
I have a Qld mate who also mentioned that Foxwing is what he is going to purchase, so I will certainly have a look at them.
Thanks for the post
KEN
713560
