Shortcut across Strzelecki Reserve
Submitted: Friday, Jan 14, 2011 at 08:29
Member - TonBon (NSW)
Ok, i know this question was asked on here about 2 years ago but i am pretty sure no difinitive answer was able to be given. Aparently there is a track that runs between the Srtzelecki Trk and the road that runs from Merty Merty to Cameron Cnr, however the best i can find is a trk that starts at -28° 56' 36.68", +140° 7' 1.53 and runs parallel to the Strzelecki Ck up to Merty Merty. The one im thinking of runs almost directly E to W cutting out that whole loop north and south again.
Would really appreciate it if anyone has co-ordinates or a log file of this track they could share with me. I am planning on heading out there in August and if found and successfully navigated i will be uploading the trek file onto here for future reference.
Tony.
Reply By: Member - Stephen L (Clare SA) - Friday, Jan 14, 2011 at 08:38
Hi Tony
Is this the track that you are talking about?
Image Could Not Be Found
If it is, I have not had the chance to drive it yet (Was going to drive it last year but rain put an end to it) Google Earth makes is a very defined track to follow.
441764
Follow Up By: Member - Stephen L (Clare SA) - Friday, Jan 14, 2011 at 08:41
Here is a blow up of the area.
713868
Follow Up By: Member - TonBon (NSW) - Friday, Jan 14, 2011 at 09:37
Cheers Stephen, that definitely looks like it could be it. Didnt have access to Google Earth here at work so that was the only online map i couldnt check, cheers for that, will upload onto GPS when i get home. Thanks mate.
713878
Reply By: Allan B (Sunshine Coast) - Friday, Jan 14, 2011 at 09:34
Yes that's the shortcut from Bollard's
Lagoon to the Strzelecki. Used it several times in Santos days and last drove it in 2009. Not a public road and not maintained of course. Can be confusing with side-tracks so keep an eye on your navigator. Some boggy sections when wet. Nothing special to see but can save some mileage.
441776
Follow Up By: Member - TonBon (NSW) - Friday, Jan 14, 2011 at 09:39
Good info Allan, cheers. The mileage is a bonus but also keen on just getting off the beaten track and seeing something different. Thanks for that, hopefully by August a lot of that area would have dried out a bit.
Cheers.
713879
Reply By: Bruce M - Friday, Jan 14, 2011 at 10:15
TonBon
I drove this track in July, having been alerted to its existence by another traveller. It was reportedly less cut up on the wet weather than the main track.
When I drove it (in both directions - we stayed at
Cameron Corner overnight) it was certainly in better condition than that part of the main track from
the junction through to
Cameron Corner. The report I was given indicated that there was some deep mud on the main track at that time.
To help you find it, its eastern end joins the main track at end at S28.81359 E140.26428. Its western end leaves the
Strzelecki Track at S28.96764 E140.12902 (both waypoints taken from my GPS track). I'm sending you by email a copy of that track.
Bruce M
441782
Reply By: Member - John R (cQld) - Friday, Jan 14, 2011 at 10:28
Was it thread 67193 you were looking at? That shows a different version of the shortcut. I think there is another thread somewhere about this shortcut, but it may be hard to find now. There is definitely a road marked off the
Cameron Corner road with "T-junction" signpost (don't have its location, sorry) but that won't help if you're coming from the other direction.
Cheers, John
441784
Follow Up By: Member - John R (cQld) - Wednesday, Jan 19, 2011 at 10:42
From the GPS data given in this thread, and a look on Google Earth, the shortcut as given on the map above by Stephen is correct, and the map given in post 67193 is not. Still not sure though which signpost marks the turnoff.
714384
Reply By: Peter_n_Margaret - Friday, Jan 14, 2011 at 20:38
I drove that track 10 years ago, or probably more, I reckon. Have not driven it since.
Came past the Strzelecki end in November 2009 and it was signposted. I recall seeing a signpost at the other end at some time in the past too.
That HEMA map is the first time I have ever seen it on any map.
OKA196 Motorhome
441846
Reply By: over50ncroozin - Friday, Jan 14, 2011 at 22:52
mmm my first post here, still fiddling but you need to turn off the merty merty / Camerons rd at the
sign with no name and the red mudguard on it :)
The other end of the track is right next to the bridge with the best looking
water under it i've seen for ages :)
I attempted this Track last August 2010 but got bogged not far into it:(
I only had enough
fuel to make it to
Arkaroola (going the merty way) so I bailed out of the unknown track and went with safety via merty :)
441861
Follow Up By: Member - TonBon (NSW) - Saturday, Jan 15, 2011 at 11:23
Good stuff, cheers for that, always good to kow landmarks. Hopefully this August wont be as boggy :-)
714000
Reply By: over50ncroozin - Sunday, Jan 16, 2011 at 21:38
Yep. i would never have found it if it wasn't for the red mudguard, i did get tempted to turn at earlier tracks, which would have lead me knowhere and using fuel i needed, but relied on the good info i had at the time. Wish i could have done it, but oh
well, next time if i'm alive long enough :)
442054
