headkights on warning where to purchase?
Submitted: Saturday, Jan 22, 2011 at 15:17
Member - bungarra (WA)
Have googled and ebayed to no avail............maybe my terminology is wrong !
All I want is to purchase a simple buzzer and wiring loom that will warn me when the lights are left on when I turn the ignition off
You would think Toyota could have managed that in the 79 series for the price we pay............
can find buzzers as stand alone but wouldnt know
where to start without a wiring diagram
I can find products that buzz if lights left on and door opened..that would drive me mad as there are plenty oif times that would be normal....opening gates on the way home or simply dropping off a passanger
Can somoene point me in the right direction please for a where to purchase a warning buzzer and loom to self install .......headlights on...ignition off...warning buzzer sounds
thanks
Reply By: Rod E B - Saturday, Jan 22, 2011 at 15:22
Supercheap
about $12
I installed so not hard
442707
Follow Up By: Member - bungarra (WA) - Saturday, Jan 22, 2011 at 16:02
thanks but they no longer stock that item
714715
Reply By: Gone Bush (WA) - Saturday, Jan 22, 2011 at 15:28
Dickies used to have them before they morphed into another Retra/Harvey/JB store.
Maybe the Jaycar website?
442708
Reply By: Motherhen - Saturday, Jan 22, 2011 at 15:30
Hi bungarra
My simple method is if the lights are on lock your door. When you can't get out - remember why and turn off the lights.
442709
Reply By: Member - Christopher P (NSW) - Saturday, Jan 22, 2011 at 16:16
mate you maybe able to get that stuff off a later model cruiser, like the 80 series, and plug into loom.
give all 4x4 at kotara a ring, explain, and they may even give you a early 100 series one, not sure on price.
442718
Reply By: Rod E B - Saturday, Jan 22, 2011 at 16:30
Reply By: Rod E B - Saturday, Jan 22, 2011 at 17:06
as for
when you googled did you use head k ights
HA HA
442729
Reply By: Member -Pinko (NSW) - Saturday, Jan 22, 2011 at 17:06
Image Could Not Be Found
442730
Follow Up By: Member -Pinko (NSW) - Saturday, Jan 22, 2011 at 17:10
All the bits are available from jaycar electronics.
Stan
714726
Follow Up By: Member - bungarra (WA) - Saturday, Jan 22, 2011 at 18:31
thanks !
I can follow that easily
714743
Reply By: Witi Repartee - Saturday, Jan 22, 2011 at 18:33
I don't want to hijack this thread, but I think this question doesn't need a whole new thread. Stan..is it possible to use your set up on a 24 volt GQ Patrol?...if so will what would I need to ask for at Jaycar?...(good company but sometimes the week end staff do not have comprehensive knowledge)
442738
Follow Up By: Member -Pinko (NSW) - Saturday, Jan 22, 2011 at 19:06
Hi WP
I am not qualified to answer you question but jaycar may.
I have used the diagram on my truck and it works
well for 12v.
May be someone else will post info
Stan
714748
Follow Up By: Bonz (Vic) - Saturday, Jan 22, 2011 at 19:19
Yep it'll work, get a 24v relay and a 24v buzzer
714749
Follow Up By: Witi Repartee - Saturday, Jan 22, 2011 at 19:21
Thanks guys...appreciated
714750
Follow Up By: Dust-Devil - Saturday, Jan 22, 2011 at 23:05
Stan
Don't bother with JAYCAR on this one, check the following URL and your home and hosed.
Narva 24V relay
You are a helpfull piece of work 'BONZARELLI', why didn't you tell him where to get the item's.
Also Stan you can get them at Burson's. If not in stock they will order in from Narva for you.
DD
714779
Follow Up By: Dust-Devil - Saturday, Jan 22, 2011 at 23:07
Ooops! Apologies Witi Repartee
So excited about knowing where to get the items required from I referred to Stan instead of your goodself.
DD
714780
Follow Up By: Dust-Devil - Saturday, Jan 22, 2011 at 23:21
WR
This is just to show that Narva do actually make a 24V 5pin crossover relay
DD
Narva 24V 5Pin Crossover relay
DD
714784
Follow Up By: Witi Repartee - Saturday, Jan 22, 2011 at 23:56
Thanks..I recognise the NARVA name from somewhere....not sure what I used their bits and pieces for. Am checking it out.
714786
Reply By: wallabyjack5 - Sunday, Jan 23, 2011 at 00:09
Coventys stock them,Lumen brand I think.
Glyn
442759
Reply By: Member - Stuart P (WA) - Sunday, Jan 23, 2011 at 03:40
all you need is a small buzzer , find
park light feed (light dimmer ) connect positive to
park lights and negative side to an ign feed
442763
Reply By: Glacier Bill - Sunday, Jan 23, 2011 at 07:54
Another simple one is to run a wire from the
park light feed to one side of a $4 buzzer , take a wire from the other side to your door light switch and when you open the door the buzzer will activate. Works a treat.
442766
