Access to rear of radion in Hilux
Submitted: Wednesday, Jan 26, 2011 at 10:53
ThreadID: 83908 Views:2475 Replies:1 FollowUps:2
How do I get to the back of the radio in an 06 Hilux.
Which wire is the mute wire.
I've wired in a Bury hands free kit, just need this last wire.
Pictures would be good.
Thank you.
Reply By: donk - Wednesday, Jan 26, 2011 at 11:01
To get the radio out remove the 3 knobs for the heater controls (pull them off)
Behind the knobs you will see 2 screws
Remove the screws and pull the radio surround panel away from the main dash,starting at the top (make sure you dont drop the clips that hold it on into the dash)
When the surround is off you will see the 4 bolts (3 on either side) that hold the radio into the vehicle
Remove the bolts and the radio will come out
No idea what wire is the mute wire though so you are on your own
Regards Don
AnswerID: 443081
Follow Up By: donk - Wednesday, Jan 26, 2011 at 11:06
Should have been 2 bolts on either side (typo)
Regards Don
FollowupID: 715135
Follow Up By: Twinkles - Wednesday, Jan 26, 2011 at 11:31
Thanks Don. I'll be onto that soon now.
FollowupID: 715137
