Navara D40 auto
Submitted: Saturday, Jan 29, 2011 at 18:15
iijmartin
Hi, just after any info on the use/recommendations/effect on warranty of auto transmission cooler for a 2010 Navara D40 t/diesel.
Also anybody using 50-60 litre poly tanks for extra diesel fitted in the tray of ute or d/cab? Obviously lot cheaper than upsizing the underbody
tank.
Really looking forward to getting our new Crusader Inspiration this winter.
Ian
Reply By: AGNI4x4 - Saturday, Jan 29, 2011 at 22:26
Ian on the cooler side .................. heat is the biggest enemy of a transmission and anything that can be done to reduce the chance of heat build up has to be a positive for it. Warranty wise unless they could prove that the fitting was detrimental to (ie lack of oil flow etc) then warranty would have to stand. As long as you use a quakity kit then all should be good good
443483
