Weight Distributing Hitch - Any clues on bargins & brands & No No's
Submitted: Monday, Jan 31, 2011 at 21:22
ThreadID: 84032 Views:3110 Replies:3 FollowUps:6
I need to start looking for a WDH for my 2007 Prado. If anyone's got a spare or knows best brands etc etc, Love to hear from you.
Regards Mick
Reply By: dereki - Monday, Jan 31, 2011 at 21:39
Do you have the Toyota bar or a Hayman Reece or simmilar?
The Toyota cast steel bars are known to fail when using a WDH. Toyota apparently only allow the use of their original tongue.
D
AnswerID: 443727
Follow Up By: Member - Mick M (VIC) - Tuesday, Feb 01, 2011 at 17:08
Its a genuine Toyota fitted Tow bar & Goose neck.
FollowupID: 715873
Reply By: Member - Graham H (QLD) - Tuesday, Feb 01, 2011 at 08:57
It would be best to fit an Hayman Reece towbar at the same time.
Last year a friend had the original Prado towbar which is a casting, snap off and the van separate from the car.
Luckily no damage except to the bar.
However it was interesting to note that the part the chains were attached to went with it which is not pleasant thought.
This incident was posted on here complete with photos.
What weight is you van as HR have different weight WDH bars for different weight vans
EG a 550 for up to 2500kg and a 750 for above that.
You will definitely notice the difference using one when towing.
AnswerID: 443764
Follow Up By: Member - Mick M (VIC) - Tuesday, Feb 01, 2011 at 17:23
The Toyota fitted Tow Bar is 2500kg Braked and 750kg unbraked.
The Van's ATM: 1,680kg.
GTM: 1,513 kg
Tare Mass: 1,338 kg
Axle Capacity 3,800 kg
Now exactly which one answers the question, I dont know.
FollowupID: 715876
Follow Up By: Member - Graham H (QLD) - Tuesday, Feb 01, 2011 at 18:13
Well if you look here which is the official HR site you will see the different models.
Yours would require the 550lb as its always wiser to err on the side of heaviness of the ball weight.
As you have mentioned you got aquaplaning probably due to the ball weight.
ball weight guide
As I said a genuine HR towbar is also advisable
After seeing my friends Toyota one I wouldnt hesitate to buy one.
His van was only about the same size and weight as yours.
Heavy duty Towbar
The heavy duty is the one to get.
Check with the member who has the WDH for sale what his is.
Easy to tell the arms have the figure stamped in them or the size is 1" is 550 1 1/8 is 750.
FollowupID: 715881
Follow Up By: Member - Graham H (QLD) - Wednesday, Feb 02, 2011 at 12:10
Dont want to be a party pooper but you would really be better off with a 550lb proper hitch as your ball weight is right at the upper end of level rider bars.
Certainly they cost more but are much better for what they do.
They are much more adjustable for differing weights for one thing and do a far better job.
Basically you get what you pay for and after having one for several years would not consider towing without one.
FollowupID: 715970
Reply By: Member - mervyn p (VIC) - Wednesday, Feb 02, 2011 at 11:56
Hi i happen to have a set of level riders 19mm bar, 150mm bracketts bought new in December never used, cost $190 will let go cheaper make an offer, bought them to fit draw bar but to many accessorys in the way, any info required contact me on 0407052003 cheers Merv
AnswerID: 443914
