Garmin Problems
Hi all,
I am having a few problems with my Garmin Nuvi 760.
I had the maps upgraded three days ago to the latest 2011 variety.
Initially the unit was running very slow, I would be through an intersection by about 30 -40 mtrs before it registered on the screen, so I took it back anfdthe dealer upgrade the software for me FOC as I had not upgraded anything on the unit since I bought it back in 2008.
Same problem, unit runs slow, and now it seems to be having trouble displaying street names, it will work OK for about 5 mins, then all street info disappears for about 10 mins, then it comes back again.
The dealer seems to think the unit is faulty and needs to go back to Garmin, I find it a bit strange that it worked perfectly until the upgrade, I am rather loath to send it back to Garmin, I will probably never see the unit again, any thoughts as to a probable cause to this fault.?
Barry H
Reply By: blue one - Friday, Feb 04, 2011 at 19:55
Barry,
Sound like a processing / RAM problem.
I have one of these units and everything other than City Explorer is loaded on the SD card.
Have a look and see if you have stuff on the Garmin which could go on the SD.
AnswerID: 444214
Reply By: Expletive - Friday, Feb 04, 2011 at 20:10
They had a recall on the 760 something to do with the battery being faulty.
I sent mine back i think in October last year 7 they replaced the unit with the 765 plus the upgraded maps.I am quite happy with this one,eventhough i did not have any problems with the 760.
Get onto there wesite to see if they are still doing the recall.
Cheers.Bob.
AnswerID: 444216
Reply By: Member - Graham H (QLD) - Friday, Feb 04, 2011 at 20:43
I had a Nuvi 310 that did that I would be past an intersection before it got there.
Got sensible and got rid of it and bought a TOMTOM.
Problem solved
LOL
AnswerID: 444219
Reply By: dereki - Friday, Feb 04, 2011 at 21:59
Sounds strange, I have a 760 and have the current maps installed. It runs better then the previous map update. It is a bit slow I guess, but not so slow that its a problem.
I have found that if I have a lot of POI's loaded things can slow down a lot and become problematic.
D
AnswerID: 444229
Reply By: Bazooka - Friday, Feb 04, 2011 at 22:50
Barry
You might find an answer at this forum - or you could post your question there. Easy to register.
AnswerID: 444235
Follow Up By: Dave(NSW) - Saturday, Feb 05, 2011 at 02:09
Or here http://www.gpsaustralia.net
Cheers Dave..
GU RULES!!
FollowupID: 716352
Reply By: B1B2 - Saturday, Feb 05, 2011 at 07:12
G'day Barry,
Have you been on the Garmin website? I found the dealers did not know finer details, but I always got on to someone who did.
I wanted to run nRoute on my Garmin Oregon 300 via laptop. The dealer said it could not be done, Garmin had it sorted in an hour by email.
Bill
AnswerID: 444253
Reply By: Bonz (Vic) - Saturday, Feb 05, 2011 at 08:38
Send it back to Garmin. Their service for repairs etc is top notch
AnswerID: 444261
Reply By: Jacko84 - Saturday, Feb 05, 2011 at 10:11
Hi Barry
I had some troubles with my 760 about a year back.
Same as your situation, immediately after I did a map upgrade the unit started to become very un reliable. It would freeze up all the time and the Bluetooth would keep dropping out whilst I was making calls. A simple power down and restart would have it back running but at times it wouldn't go 10 mins without crashing.
I contacted gamin and When I finally got in touch with an Australian service provider he told me that in my latest map update there was also a software or firmware update built in. He said there had been a glitch in the new software and sent me an email with a rollback to the previous version, from memory it was vers4.9 back to vers 4.8
Did the install and it hasn't missed a beat since, perhaps your having similar issues?
Hope it helps,
Jack
AnswerID: 444273
Reply By: Jacko84 - Saturday, Feb 05, 2011 at 11:43
Hi Barry
Hope it helps,
Jack
AnswerID: 444286
Follow Up By: Jacko84 - Saturday, Feb 05, 2011 at 11:44
Oops, sorry about the double up...
FollowupID: 716400
