200w 24v solar panels
Submitted: Friday, Feb 04, 2011 at 21:02
vicex
hi guy's looking for some help can you run 24v solar panel to charge batterie's can you put a solar management system in to do this a 12 v solar panel makes more than 12v so you need a regulator can you get a regulator to bring the 24v down to 12v thank's allen
Reply By: _gmd_pps - Friday, Feb 04, 2011 at 21:34
yes ..
I run 4 x 200W GE panels with 2 in series with 54V and the in parallel with the other 2 creating a total of up to 15Amp at typical 50V and a bit more at peak.
I use an Outback MPPT 60Amp solar regulator which does convert nicely to 12V.
It is a bit expensive here in OZ, but you can get it reasonably easy from the US, which I did with all my solar gear and batteries.
good luck
gmd
444226
Reply By: Member - Ed C (QLD) - Friday, Feb 04, 2011 at 21:51
Yes, most MPPT controllers will handle the higher input voltages...
I'm using a >>
Morningstar Sunsaver SSMPPT-15L
With the exchange rat as it is, these are quite affordable iif purchased from the good ol' U S of A ;-
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
444227
Follow Up By: Member - Ed C (QLD) - Friday, Feb 04, 2011 at 21:52
Errrm, Exchange RATE ...
Note to self.... Learn to proof-read!
| Confucius say.....
716337
