Garmin Nuvi software - convert to google earth format?
Submitted: Wednesday, Feb 09, 2011 at 23:56
ThreadID: 84248 Views:4064 Replies:4 FollowUps:1
Hi all
Been OS so not on EO for a while. Hired a car while away (Diesel Hilux 3l D4D, 12 seater high roof) – beaut beast. Did 3300km. Hire company threw in a Garmin Nuvi (not sure the model – probably 2 years old or so). I managed to download its entire file structure. Would like to generate a track file – preferably in Google earth format (.kmz file) to plot where we went. How do I do this?
Alternatively, is there someone with the software that could convert it for me – if so what file type contains the track info.?
Reply By: The Explorer - Thursday, Feb 10, 2011 at 00:24
Not all Nuvis save a track file by default (or at all) so it may or may not be present in the "file structure" you have copied from the unit. .......anyway
Have a read of this
Garmin Nuvi Tricks and Tips
AnswerID: 444871
Reply By: Member - Matthew S (WA) - Thursday, Feb 10, 2011 at 10:52
I have a nuvi as well as was hoping to do the same after my trip to Tasmania. But the Nuvi I have will only keep the last week due to memory size. So all i have is the last week from Adelaide to Perth. You may need to use a program called MapSource. I have a guy at work that does it all for me so don't ask how its done :)
AnswerID: 444917
Reply By: Member - Doug T (NT) - Thursday, Feb 10, 2011 at 15:51
2 ways you can do this,
1 download your recorded track from the GPS into Mapsource on the PC,
2 If the track you want is over main roads and tracks shown on Mapsource on the PC then create a route ....then as below for both methods.
Image Could Not Be Found
You can then save the file as a KMZ file from GE. Waypoints can be shown too if there are any and can be tuirned on or off using the menu on the left side in GE.
AnswerID: 444952
Follow Up By: The Explorer - Thursday, Feb 10, 2011 at 16:02
Possibly a better alternative to Mapsource is Basecamp. Only because its a bit easier to get up and running ...if you dont already have Mapsource.
Dont need either to view in Google Earth though - just drag the track file (*.gpx) into Goggle Earth - job done.
FollowupID: 717120
Reply By: jdwynn (Adelaide) - Thursday, Feb 10, 2011 at 23:00
thanks all, that gives me a few things to try. I dont have mapsource so will try basecamp first. Cheers
AnswerID: 445006
