LPG injection for diesel engines
Submitted: Monday, Nov 10, 2003 at 19:26
ThreadID: 8425 Views:3879 Replies:5 FollowUps:2
Gid'ay all, It would be great if someone could help, My GQ TD42 suffers from lack of legs in some of the comp's we do here. It is Turbo'd with a Safari kit and is fitted with the 3" mandrel bent exhaust. Some of the other competition trucks here are bolting on a LPG injection unit which is injected on demand like nitrox in a petrol engine. Gains of 25% in short bursts are achievable but this always comes at some expense. Have any of the readers used this system?, any help would be appreciated.
cheers.
Reply By: Mickl - Monday, Nov 10, 2003 at 20:05
I haven't used or even seen this system on a vehicle, however I've read this companys advertising material. On paper this technology looks promising. They claim up to 25% power increase by replacing 20-25% of diesel used with 15%-20% LPG. This is an Australian developed technology and the company is called Global Fuel Solutions. Contact in NSW is David Medina 02 9211 0078.
AnswerID: 36770
Reply By: Simon - Monday, Nov 10, 2003 at 20:43
Just by a nitrous kit and fit it, fix your lack of power.
AnswerID: 36776
Reply By: Kiwi Winchtruck - Monday, Nov 10, 2003 at 20:44
Thanks Mickl, yes I've seen that site too, I want to find out more so will keep looking.. The results and benefits seem too good to be true
AnswerID: 36777
Follow Up By: Mickl - Monday, Nov 10, 2003 at 22:26
http://www.transport.nsw.gov.au/ministerial-inquiry/Global-Fuel-Solutions.pdf
The last page of the above pdf has some technical information.
These two are uk sites also with some technical info. I think these systems are different to the OZ one (not as sopisticated) but I haven't had time to read all the info.
http://www.ilovesponge.com/spongecars/diesel/diesel.htm
http://www.lpg-kits.com/hgv.htm
FollowupID: 26593
Follow Up By: Mickl - Monday, Nov 10, 2003 at 22:52
Here's another one from US. Propane injection setup claiming power increase up to 65% on turbo diesels.
http://www.dieselperformanceproducts.com/home.html
FollowupID: 26596
Reply By: Truckster (Vic) - Monday, Nov 10, 2003 at 22:58
Why not just go with a 350 chev conversion, would be better.
sell the TD and Safari seperate to recover costs..
There was on LPG inject that went poo and blew holes in 2 pistons on a GQ.. cost him a new block and pistons and crank etc..
AnswerID: 36799
Reply By: howesy - Tuesday, Nov 11, 2003 at 18:51
looked into those systems some time ago and they were designed to run with a slightly leaner diesel ratio. adding the LPG to a full flow diesel ratio could end up giving you the same headaches as regular overfueling which over extended periods can be desastrous so I suggest you do your homework very well because diesel engines don't come cheap.
AnswerID: 36890
