triton Rims - Wheel dilema
Submitted: Saturday, Feb 12, 2011 at 20:53
ivegonefishing
hi all,
I have recently purchased a ML triton GLXR (fitted with factory alloys). I want to run a second set of
wheels and looking to purchase 16x6 steel rims from a MK triton.
a friend has indicated that the steel MK rims may not fit due to the offset difference between the steel and alloy rims.
can anyone assist with an answer if the MK steel rims will suit a ML GLXR?
thankyou
Reply By: landseka - Saturday, Feb 12, 2011 at 21:08
Go
here and ask any Triton related questions. They are a helpful bunch.
Cheers Neil
445219
Follow Up By: Member - Christopher P (NSW) - Saturday, Feb 12, 2011 at 22:24
go to the local wrecker and see if he has one. take a jack with you and try on on onside. front and back, check clearance on disc and drums, front
wheels up in the air and from lock to lock. you may get lucky.
i put disc brakes on a daewoo lanos, the standard 13" rim binds on the rear caliper, so got a 15" wheel off donor car fixed the problem.
717475
