4 runner rear coil replacement
Submitted: Thursday, Feb 17, 2011 at 22:04
wollyw
i have a 1991 4 runner and thinking of updating the 20 year old rear springs to help with the rear end sag.
anyone got any thoughts, suggestions, advice
Reply By: Roughasguts - Thursday, Feb 17, 2011 at 22:11
Air shocks might be a better idea!
445826
Reply By: Member - Ruggers - Friday, Feb 18, 2011 at 02:18
try air bags that fit inside
the springs
445834
Reply By: Ruffy-Dan - Friday, Feb 18, 2011 at 07:25
Hey Wolly.
Firstly work out what you want from the vehicle. ie, towing, improvement in handling, just return to former glory..
Then seek advise from a
suspension specialist on the spring rate requred to achieve the result you want.
'Assuming" your shocks are ok and you just want to replace rear coils then DONOT under any circumstance consider fitting an airbag to the rear to compensate for sagged coils. You will be masking a problem with an exspensive bandaid.
Coils shouldn't cost you more the $350 all fitted, possibly less.
DAN
445838
