repowering 60 series cruiser
Submitted: Thursday, Feb 17, 2011 at 22:51
ThreadID: 84436 Views:3645 Replies:5 FollowUps:3
hi all , looking into repowering the ol" 60 . Has the old 2h power plant with 470thou on the clock and still in reasonable condition enginewise and bodywise. More the point just got it to where i like mod wise and dont want to have to go through uninstalling and reinstaling in another. The ol girl is just getting tired , doesnt blow smoke but just struggles on long trips which with the club which could be a 6-700 k round trip for a day trip here in the
pilbara. Do i recondition the 2h or look for something a bit newer and fresher , not iterested in v8 conversions as fuel economy is an issue with long distance touring in the mix. cheers in advance, wayne
Reply By: Rockape - Friday, Feb 18, 2011 at 08:15
Mate easiest way is to install a fully rebuilt 12ht if you can find one. This means no mods to your current setup.
Next you could install a 1hz or 1 hz turbo, this creates problems with aircon, exhaust and radiator also you would probably be wise to rebuild unless you can get a low K model
The 12ht is a great engine and is up there in the horsepower department.
As for the chev V8, mine uses less fuel than my old 2h and towing it is not using anymore than the new Tojo V8's.
Have a good one.
AnswerID: 445843
Follow Up By: Batt's - Saturday, Feb 19, 2011 at 00:51
Hey rockape your V8 would be a lot cheaper to run because it wouldn't chew oil like the u-beut tojo V8
FollowupID: 718251
Reply By: Batt's - Saturday, Feb 19, 2011 at 00:47
G'day I've had 2 x 60's before 2H & 12HT the 12HT is a brilliant motor but are very expensive to buy I think their still around 6 grand I think if you were looking at reconditioning the 2H look at turbogharging it tell the mechanic so he can rebuilt it to suit. denco would probably be one of the better turbo's to use for the long term with a 2 1/2 inch exhaust it would be like a new car good luck anyway
AnswerID: 445946
Reply By: Member - Tony (ACT) - Sunday, Feb 20, 2011 at 17:45
Yoy could also think about a Turbo Deisel out of a 80 Series, been done a lot.
AnswerID: 446063
Follow Up By: Member - pilbara60 (WA) - Sunday, Feb 20, 2011 at 19:51
Hi to all and thanks for the adviice. Just have to decide if worth the time and expence or to update to newer vehicle . cheers wayne
FollowupID: 718383
Reply By: Member - Burto (NSW) - Monday, Feb 21, 2011 at 17:45
Hi, just gone through the same exercise, 2H with 520 000k's on the clock, had a turbo kit fitted, good improvement, then rebuilt the motor, in chassis, new pistons, rings, piston pins, new mains and thrusts, new bigends, head cleaned and surfaced ground, new pre-combustion chanbers, new valves and new exhaust valve seats, all parts were ex Japan from known companies, engine rebuild cost total $2500.00.
Now great vehicle to drive and tow with, hope this helps
AnswerID: 446190
Reply By: Member - Burto (NSW) - Monday, Feb 21, 2011 at 17:55
hi, know how you feel just went thru the same exercise, 2H with 520000on the clock, had a turbo kit fitted performance better but not great, time to do the motor.
Did a in chassis overhaul, new pistons,rings and piston pins, new mains and thrusts, new big ends, had head cleaned and surfaced ground, new pre combustion chambers, new valves and new exhaust seats, all parts ex Japan from known companies. Total cost incl oil, filter, and ball hone $2500.
Result a pleasure to drive and tow with. Done a couple of short trips, all well now heading off to Tas in 2 weeks.
AnswerID: 446191
Follow Up By: Member - pilbara60 (WA) - Monday, Feb 21, 2011 at 19:50
sounds the way to go for me. just have to find someone here in the pilbara to do it for me
FollowupID: 718522
