solar conection to deep cycle battery
Submitted: Sunday, Feb 20, 2011 at 09:19
christo2510
Hi all, what is the best way to connect my 12v fridge/freezer to my 120amp hr. deep cycle battery whilst also connecting my 80 watt solar pannel.
Is there a connection device around that will provide better efficency when all connected.
Are alligator clips from frinfge and pannel onto the battery terminals going to cut it?
Will I lose power along the way with clips?
The solar has a regulator and the fridge has low voltage cut out.
Reply By: Tonyfish#58 - Sunday, Feb 20, 2011 at 09:31
To keep it simple? Connect Panel straight to battery. Set up a fused Anderson plug that you can connect the fridge to, keep the wires as shrt as possible.
If you want to run other things, then set up a fuse block.
Cheers Tony
446023
