CaravanTV Antennas
Submitted: Monday, Feb 28, 2011 at 16:00
ThreadID: 84675 Views:3357 Replies:4 FollowUps:0
Looking to fit an antenna to my Coromal pop top. Any body got any advice which is best all rounder and how good is the bracket that fits to the pop top clips. All replies appreciated. Jim
Reply By: snailbait (Blue mntns) - Monday, Feb 28, 2011 at 16:47
Hi jim k
There is no best all rounder aerial, there is a roof top aerial whitch is good for horizontal frequencies but you must have it modified to also take vertical signal, i am in tas and they have alot of vertical signal talk to you caravan dealer, this is a wind-up that sites on the roof
Terry
Life MEMBER snailbait Oberon HF RADIO CLUB VKE237 mobile 7661
AnswerID: 446893
Reply By: Member - barry F (NSW) - Monday, Feb 28, 2011 at 18:49
Hi Jim, have a look at threads 56196 & 296176 which might be of some help to you.
We used to have a pop top with a wind up Wynegaurd (spelling?) which was beaut but current van which is also a Pop Top does not have one of these so we purchased a Digimatic from Dick Smith which we are very happy with. It comes with an amplifier & which needs 240V power & as we mostly stay on powered sights this is not a worry to us.
As to the bracket that fits to the Pop Top clips, we purchased a set from Jayco a couple of years ago at about $30 if my memory is still intact! They are of simple design & very easy to set up. But they looked a bit "plasticy" to this old timer & being a bit of a handyman I copied them & made some decent ones from some aluminium. Best of luck & cheers.
PS. If I had my way, I would leave the Telly at home as I love to sit outside under the annex or a tree & just take in the atmosphere of our location. SWMBI loves her Telly, so reception is high on her list!!
AnswerID: 446910
Reply By: Pacer59 - Monday, Feb 28, 2011 at 19:57
Hi Jim
I have a pop top van with a “Happy Wanderer” antenna – bought from a Dick Smith store in Melbourne 3 years ago. About $90 which included antenna, mounting bracket and approx. 5 metres of cable with plug fitted. Bracket is fitted to the van roof and no problems – very easy to fit antenna and take down –takes about 2 minutes to screw the antenna on, align (simply check other van antennas nearby) and plug cable in.
Unit can be used horizontally or vertically – simply unscrew wing nut and adjust. Excellent digital reception all over OZ – Victoria, SA, WA (Perth, Geraldton, Broome), NT (Alice Springs, Darwin), QLD ()Port Douglas, Cairns, Brisbane)
Hope this helps
Rob
AnswerID: 446924
Reply By: BFreer - Wednesday, Mar 02, 2011 at 16:18
I have used the Happy Wnaderer basic antenna (PVC pole type, about $100)with failry good results when fitted with amplifier but did find it struggling in some fringe areas. Noticed that vans using the Happy Wanderer Active 1 antenna were out-performing me all the way, and never heard a negative about their performance. Also noticed some good reviews about this antenna on a number of RV forums. Went and got one, about $250, but well worth it. Very compact, easily adjusted to vertical or horizontal, comes with a good amplifier, cables etc. Seems to be comparable performance wise with the Explorer antennas but more compact.
AnswerID: 447096
