Thick sidewall Tyres
Submitted: Monday, Feb 28, 2011 at 16:23
ThreadID: 84678 Views:5192 Replies:11 FollowUps:4
Related Pages
I'm looking for tyres that have at least 4 ply sidewalls. There used to be a Bridgestone 'Jeep Service' Tyre that was an 8 ply tyre that had 4 ply sidewalls but that was maybe 15 years ago.
Any suggestions
regards.........jeff
Reply By: stevie1947 - Monday, Feb 28, 2011 at 19:23
I seem to recall that my last 4x4 had Cooper ST's which were 8 ply walls.
Stand corrected if my memory is wrong!!!!!
AnswerID: 446915
Follow Up By: Crackles - Monday, Feb 28, 2011 at 20:34
8 ply Steve but not in the wall. And it seems not all wall ply ratings are equal between brands either as Cooper ST's are far thinner than tyres like Procomp's Exteme series or Goodyear MTR's in fact ST's would be one of the last ones I'd choose if specifically after sidewall protection.
Cheers Craig.
FollowupID: 719276
Reply By: Member - barry F (NSW) - Monday, Feb 28, 2011 at 19:28
Maybe ask a tyre retailer or tyre wholesaler?
AnswerID: 446916
Reply By: Isuzumu - Monday, Feb 28, 2011 at 19:43
Most MT tyres have a 3 cord side wall and now use denier cord
Site Link
this link may explain it
AnswerID: 446920
Follow Up By: Member - MUZBRY(Vic) - Tuesday, Mar 01, 2011 at 06:47
Gday Bruce
" Denier " is the way cord is measured,ie. your wifes stockings are 15 or so denier.
Murray
FollowupID: 719308
Reply By: Tonyfish#58 - Monday, Feb 28, 2011 at 19:48
Maxxi - These will give you grip
My Maxxi Bravo 753 seem strong enough :-)
Cheers Tony
AnswerID: 446922
Reply By: Member - Trouper (NSW) - Monday, Feb 28, 2011 at 19:56
Thanks all
regards........jeff
AnswerID: 446923
Reply By: SPRINT-GTO - Monday, Feb 28, 2011 at 21:26
Check out the Bridgestone Dueler D694LT (light truck) Ithink these may be what your seeking.
AnswerID: 446941
Reply By: splits - Monday, Feb 28, 2011 at 21:56
jeff
When you said Bridgestone Jeep Service tyres, do you have a heavy 7.50x16 in mind? If that is the case, have a look at thread 62006 on this site. They don't come much heavier than those things.
AnswerID: 446945
Follow Up By: Mick O - Tuesday, Mar 01, 2011 at 08:34
Yep but be mindful of what use you're putting them too. From that blokes personal website;
"In hindsight I erred on the side of tyre choice as the heavy duty cross-ply tyres were unsuited for soft sand driving and towing and I had some issues with small pebbles getting into the casing cavity and puncturing the tubes. I also had the misfortune of spinning the rims on the tyres when at 10psi and thus breaking the valves off the tubes. Lesson learned!"
For some definitive info on MRF's I'd probably look here;
Mick Huttons tyre page
Cheers Mick
FollowupID: 719313
Reply By: Rod - Monday, Feb 28, 2011 at 22:08
If you want tough, have a look at MRF tyres from India.
AnswerID: 446950
Follow Up By: Madfisher - Monday, Feb 28, 2011 at 22:30
I think thats what Willem use to use for desert use.
Cheers pete
FollowupID: 719289
Reply By: Member - Jdub - Tuesday, Mar 01, 2011 at 00:02
G,Day Jeff, Apart from the ply wishes, it depends on use. Whilst the MRF,s are tough, they do limit sand hill crossings and braking on wet bitumen.
Sidewall construction varies with some having thicker and closer spacing of the cords but IMHO 3 plies are max for a radial.
AnswerID: 446963
Reply By: Whitewulf - Tuesday, Mar 01, 2011 at 08:15
Could look at Micky Thomp tires the ATZ has 3 ply side walls, I find them a middle between Bridgestone Dueler D694LT and a MT.
http://www.mickeythompsontires.com/truck.php?item=BajaATZRadial
AnswerID: 446979
Reply By: Member - Trouper (NSW) - Tuesday, Mar 01, 2011 at 11:57
Thanks Fellas yes it was the MTR's I was concidering but couldn't remember the name, their for the Troopy but i think a 3ply would do and will look at that
AnswerID: 447001
