waterproofing a new shower in bus
Submitted: Monday, Feb 28, 2011 at 20:36
bescat
Hi' we are building our own mobile home and would like to know if there are cheaper alternatives to using pvc wall panels in the shower. Has to be a good waterproof material, and what should we use for the floor as its an odd shape and cant get a mould to suit. We live in WA, looking forward to any help members can give as
well as tips. thanks
Reply By: Roughasguts - Monday, Feb 28, 2011 at 20:44
How about flow coat! the stuff they use over the top of the ply flooring on fibreglass boats.
Putting it on is a bit tricky as it's quite tacky and lumpy thats why they spatter another coat of a differant colour over the top to mask it.
Cheers.
446933
Reply By: Eric Experience - Monday, Feb 28, 2011 at 21:04
I use painted steel for showers it is lighter than PVC and can flex with the body.
I go to a white goods manufacturer and get prepainted steel that is a lot easier to clean than colour bond. Eric
446935
Reply By: Polaris - Monday, Feb 28, 2011 at 21:47
Hi - we went through the motorhome construction back in 2005. Started with a bus full of seats - and the end result is on the cover of the CMCA journal "The Wanderer" - current issue February 2011.
I used lamipanel to sheet the shower
toilet walls and ceiling. Used genuine lamipanel internal corner, external corner and straight joiners.
No mould or leak issues. Another good trick is to give the whole interior surface a good polish with automotive product BEFORE ever using it. The
water beads and runs off like off a ducks back and soap also doesn't stick as easy.
Some construction photos including the bathroom can be seen
here
446942
Follow Up By: bescat - Tuesday, Mar 01, 2011 at 00:18
Thanks for the post and the pictures by the way you have done a great job
719301
Follow Up By: Polaris - Tuesday, Mar 01, 2011 at 11:01
You're welcome.
About a years work - part time.
But very satisfying and rewarding to know we did it ourselves, and can't blame anyone else if something goes pearshaped! LOL !!
719319
Reply By: bescat - Tuesday, Mar 01, 2011 at 00:20
thankyou for your posts will take all on board
446965
