Where to buy a staun masso jet from in perth or online
Submitted: Tuesday, Mar 01, 2011 at 18:54
ThreadID: 84705 Views:4409 Replies:3 FollowUps:5
Hey guys wanting to buy a staun massojet cleaner and i am just wondering where i can buy them in perth wa and if there are so sites online i can but from
Reply By: Member - Tanka (NSW) - Tuesday, Mar 01, 2011 at 19:18
Seriously, type staun massojet cleaner in google. You will find online stores in less time than it has taken me to write this reply.
Cheers Tanka.
AnswerID: 447025
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Mar 01, 2011 at 20:33
Maybe a pressure cleaner would be better rather than a bit of bent tube with a nozzle and a ball valve..(at garden tap pressures) Fairly ordinary from what i can see!! Michael
FollowupID: 719364
Follow Up By: Member - Boeing (PER) - Tuesday, Mar 01, 2011 at 22:41
Tanka, You have to wonder!
Mark
FollowupID: 719378
Follow Up By: equinox - Wednesday, Mar 02, 2011 at 00:28
Seriously Tanka, you actually Google the answer, however instead of answering Navara's question you patronise him. Very poor form in my opinion.
How do you know that he/her doesn't even know what Google is? Perhaps next time just keep your fingers quiet hey?
FollowupID: 719384
Follow Up By: Member - Tanka (NSW) - Wednesday, Mar 02, 2011 at 11:34
Equinox,
I had no idea what a staun massojet cleaner was. I copied and pasted from the OP and entered it into google. I'm sure most search engines would produce the same results. I'm sure if the OP did not know how to use a search engine he would never have found the exploroz site. I found two online sellers in the top 5 results. I was not being patronising, just pointing out that, actually having a look yourself first can yield results quicker than asking a forum to do the looking for you. I think if you have a look at my posts on this place I try and help when I can, and don't go looking for trouble.
Also I think you will find that my post was much more helpful to the OP by showing him where to find results, than yours which is just about bagging me.
Cheers Tanka.
FollowupID: 719406
Reply By: Member - Duncan W (WA) - Tuesday, Mar 01, 2011 at 20:56
ARB, TJM, Opposite Lock and just about any other 4wd accessory store sell them.
I have one, would I buy another most probably as they do allow you to reach further under the car without getting drowned. Good for getting into the chassis frame and small holes etc but if you use the detergent reservoir it runs out that quickly that you are for ever running backwards and forwards to the tap to refill it.
A pressure sprayer will do the job or a small jet attachment for the garden hose.
Dunc
AnswerID: 447032
Follow Up By: SPRINT-GTO - Tuesday, Mar 01, 2011 at 23:28
Agree with Duncan, I have one and I get better results with a garden hose.
Have fitted it up to my compressor but not much better than garden hose!!
I wouldnt buy another one.
FollowupID: 719380
Reply By: gbc - Wednesday, Mar 02, 2011 at 00:16
Do you know a plumber?
A length of hard drawn bent a few times into the appropriate shape, belt the end flat to make a fan and put a gate valve and hose adapter on the other end. Mine's ten y.o. and doing fine.
AnswerID: 447052
