UHF & Next G connector wall fittings
Submitted: Saturday, Mar 05, 2011 at 13:43
ThreadID: 84798 Views:4759 Replies:3 FollowUps:4
I wish to have a Next G antenae on a caravan that is removable for when travelling.
The antenae lead I have is fitted with the standard fme male connector for joining to a patch lead. Ideally I would like to be able to fit this connector into its female fme mate on a wall plate of some kind so it is easily attached / detached alomg the lines of a satellite TV fitting that is common a wall plate of caravans.
Obviously I need a lead for between the phone/ intenet device fitted with the male fme and the other end requirs the female fme onto the outside of the 'van wall......but what is there that gives a solid connection as I dont want a floopy end hanging out of the wall to the outside?.
The same applies to the UHF antenae.......some form of solid fitting suitable to adapt to a wall plate of some kind that allows the PL259 from the antenae to join into the lead from the radio coming from inside the 'van to the poutside wall
The more I google the more confused I get simply because I cant work out what these fittings may be called
thanks if you can help me
VKS 1341
Reply By: Snoopyone - Saturday, Mar 05, 2011 at 15:20
Look up a Jaycar catalogue and it may be there.
You could always buy the through the wall TV unit that allows you to pass a cable through it without connectors.
Cant remember its name but would do the job.
AnswerID: 447404
Reply By: nick b - Saturday, Mar 05, 2011 at 21:50
try a antena shop or person ........... let your fingers do the walking !!!!!
AnswerID: 447422
Follow Up By: Member - bungarra (WA) - Saturday, Mar 05, 2011 at 22:00
thanks but I did state that I had googled
VKS 1341
FollowupID: 719731
Follow Up By: nick b - Sunday, Mar 06, 2011 at 13:00
let your fingers do the walking " that's yellow pages "
does that mean you cant find antenna specialist who can supply you ?
FollowupID: 719750
Reply By: Gone Bush (WA) - Saturday, Mar 05, 2011 at 22:03
BG,
when are you getting your van?
If you like, depending on when it is in your hands, I can help with quite a few different fittings and a crimping tool.
If you're up here or we can take a run to Harvey.
This is the "through the wall" device mentioned earlier:
Image Could Not Be Found
These are available in Mandurah. I've got a spare one too. These avoid a connection which is a good thing.
If you are going to put it through the wall, make sure you get some construction photos of your van BEFORE the external cladding goes on so you know where the van's wiring is.
Keep in touch.
AnswerID: 447423
Follow Up By: Member - bungarra (WA) - Saturday, Mar 05, 2011 at 22:16
Hi GB
Thanks for that...van chassis will be started the week commencing March 14th. Planned delivery is the week before Easter...hence me starting to get a few things in place.
appreciate your offer. I have to nip up to Broome this coming week for a couple of days and so I will touch base with you the following week and go from there
G
VKS 1341
FollowupID: 719734
Follow Up By: Gone Bush (WA) - Saturday, Mar 05, 2011 at 22:19
OK, make sure you insist on heaps of construction photos.
FollowupID: 719735
