Replacing Tyres on NM Pajero Exceed
Submitted: Wednesday, Nov 12, 2003 at 21:02
squeezy
I am looking at replacing the original tyres on my NM Pajero Exceed DID Auto and I am considering 285 75 R16 tyres to replace std 265 70 R16. This will give me an addition inch clearance in height and a bit more width. I have just replaced
the springs and shocks with new TJM springs and Bilstein shocks. and vehicle ride has and height has certainly improved on a recent trip towing my trackabout offroad camper. I know that my speedo will also need adjustment ??? Any comments would be appreciated.
Reply By: STAN - Wednesday, Nov 12, 2003 at 21:23
I replaced the original Toyo tyres with BFG AT 265 75 R16 . It has JUST enough clearance with standard
suspension. They are fractionaly noiseier. The speedo now runs spot on. The solid spare wheel cover no longer fits.
Best of luck Stan
37075
Reply By: Matt (W.A.) - Thursday, Nov 13, 2003 at 09:49
Squeezy,
I too replaced the original boots with Cooper ST (265/75/R16) before the
suspension Mods the boots rubbed on the inside of the wheel arch! (@ full lock)after I put taller HD Springs it wasn't a problem with 285's the only thing you may have to be carefull of is when your
suspension is fully compressed you may get wheel arch rub on the top, I think it will be a tight fit it all depends on how much lift you got from the
suspension Upgrade.
HTHKeep It On The Rough Stuff
Matt (W.A.)
37137
Reply By: Richard - Thursday, Nov 13, 2003 at 20:52
I replaced the standard Geolander H/T (not sure why they put an HT on a 4WD) with Bridgestone A/T's following previous experience on another vehicle which had limited 4WD work.
After 60K in the current vehicle I've had 4 punctures. Two with nail holes repairable with a plug. One nail through the sidewall which wasn't repairable. The other a sharp rock through the steel belt in a washaway which also wasn't repairable. Three original tyres now need replacing and I'm doing some homework.
Looked at the comparo in a magazine and done some stats based on my usage. Already convinced myself I won't be buying the same brand again but the favorites are either expensive or had some bad publicity.
There is also the dilema on the best way to move across to a different brand/tyre all round.
37232
