Inverter Info
Whats happened to the section about Inverters, I just told my Daughter down in Orange that I'd send her the EO link explaining the info about Pure Sine Wave Inverters for laptops and it's not there, I looked in TOPICS / Power & Electrics, nothing shown.
Reply By: Rockape - Sunday, Mar 06, 2011 at 22:30
Doug
HERE
Have a good one
AnswerID: 447521
Follow Up By: Member - Doug T (NT) - Sunday, Mar 06, 2011 at 22:34
Thanks mate , where was the link...????
FollowupID: 719809
Follow Up By: oldtrack123 - Sunday, Mar 06, 2011 at 23:25
Tell her to completely ignore this section, As it is TOTALLY INCORRECT[apart from the electrocution risk]:
Safety Issues
Quote
Electrocution
The 240 volts from an Inverter can kill you instantly, just like the 240 volt at home, so you need to take precautions. All modern houses have a Safety Switch (or Earth Leakage Circuit Breaker - ELCB or Residual Current Device - RCD) to cut off power quickly if someone touches the 240 volt while earthed - but many Inverters do NOT have them. Safety Switches will only protect against electrocution to earth if you connect the Earth Terminal on the Inverter to an earthing rod that has a good earth connection - a rod into dry sand is useless.
TIP Always use a Safety Switch at the Inverter if one isn’t built in - it’s very cheap protection against a fatality."endQuote
DO NOT EARTH THE GENERATOR.!! DO NOT USE AN EARTH ROD!!
A PLUG IN TYPE RCD will not be functional!!!
A safety switch SHALL be permanently fixed & PERMANENTLY CORRECTLY WIRED to be functional
THOSE ARE THE RULES
FollowupID: 719816
Follow Up By: Rockape - Monday, Mar 07, 2011 at 06:06
Doug,
I had seen it somewhere before, so I just tried inverter in the search section at the top right hand side of this page.
Have a good one
FollowupID: 719822
Follow Up By: Member - Keith C (NSW) - Monday, Mar 07, 2011 at 10:29
G/day Peter,can you tell me where to get a safety switch I use an inverter in my van off the 12v supply often.Regards Keith
FollowupID: 719838
Follow Up By: dbish - Monday, Mar 07, 2011 at 10:43
Hi Keith, A safety switch will not work on an Inverter as they are an Isolated power supply & its earth conection only goes to the outside shell of the inverter.
FollowupID: 719839
Follow Up By: Member - Keith C (NSW) - Monday, Mar 07, 2011 at 11:01
Ta dbish ,that clears it up.regards ,Keith
FollowupID: 719842
Follow Up By: oldtrack123 - Monday, Mar 07, 2011 at 12:11
Hi Keith
Your inverter is safe AS LONG AS IT & THE ENTIRE CIRCUIT [it is connected to] REMAINS ISOLATED.
IF a fault to earth develops ANYWHERE in that inverter or circuit ,IT IS NO LONGER ISOLATED
Isolated inverters are relatively safe if only being used with double insulated devises, however it is recommended that ONLY ONE devise which requires an earth connection[3pin plug] be connected[PLUGGED IN]@ anytime.
The highest risk occurs if the inverter is plugged into the van inlet socket
The van RCD WILL NOT BE OPERABLE
SHOCKS & Deaths have occurred using isolated inverters when the above fault has developed!!
You may wish to contact.
Ian @
www.powerstream.com.au
They have a devise [not sure if it is on the market yet] that does not require modifications to the inverter & give a very high level of safety in all circumstances
Usual disclaimer: I have no interests in the company finiancial or other wise but have a tecnicali nterest in the devise
FollowupID: 719848
Follow Up By: Member - Keith C (NSW) - Monday, Mar 07, 2011 at 14:01
Thanks Peter,I will check on his site. regards Keith
FollowupID: 719861
