check lift on d40 navara
Submitted: Friday, Mar 11, 2011 at 07:46
ThreadID: 84919 Views:2454 Replies:3 FollowUps:3
any one got a d40 with lift so i can compair it with mine.i have arb steel bull bar with 9000 warn winch running 265/75 tyres on 16inch wheels.cheers warren
Reply By: Member - warren G (VIC) - Friday, Mar 11, 2011 at 08:58
forgot to add mine has 40mm lift .warren
AnswerID: 447892
Reply By: Member - Coxy108 - Friday, Mar 11, 2011 at 08:58
Warren,
I have a D40 with a lift. What do you want to know?
Steve.
AnswerID: 447893
Follow Up By: Member - warren G (VIC) - Friday, Mar 11, 2011 at 09:24
i added more info but i think my lift has dropped after being on for two years ond 40000k.doing cape york shortly and prepairing car for trip .cheers warren
FollowupID: 720248
Follow Up By: Member - Coxy108 - Friday, Mar 11, 2011 at 09:34
Sorry Warren, I didn't see the additional info.
Unfortunately I have a bigger lift than 40mm so can't help you with measurements but I can tell you that the original leaf springs that I had put in the rear were OME and they sagged quite badly after about 18 months (in fact they were inverted!). I have just had a set of custom made leafs put in to fix that problem.
Steve.
FollowupID: 720249
Follow Up By: Member - warren G (VIC) - Friday, Mar 11, 2011 at 16:23
i had my leaf springs drop so fitted air bags the front looks low to so wanted to check if someone had same.would not fit ride-pro susspension again cheers warren
FollowupID: 720282
Reply By: Member - warren G (VIC) - Friday, Mar 11, 2011 at 09:16
it is a 2008 diesil auto and measure should be fromm center of diff.sorry i left this out
AnswerID: 447895
