Friday, Mar 11, 2011 at 13:59
Hi Matt,
I have an 80 series TD multi valve and have just had the motor done up , only because I was chasing the annoying tick that they are notorious for.
I did not get rid of the tick and the motor is going slightly better but not much better which tells me that at 290,000 K she did not want doing, I was going fine anyway. Injectors were another $3500 on top.
The rebuild cost about $5500 at the motor rebuilder and $1400 at the mechanic to pull it out and put it back.
I have gas on
mine as
well and it goes like a rocket.
The 97 models are fairly few and far between, they were the last of the mohecans so to speak.
Good ones are still fetching
well over $20,000.
If you can't afford a diesel then by all means get yourself a petrol as they are quieter, smoother, less servicing and cheaper to service.They are also much cheaper to buy.
As a previous responder said the petrols cost around $2500 to $3000 to rebuild.
I previously had a petrol 97 on gas and it was brilliant returning as good economy or better than a turbo diesel, kilometres per dollar that is.
The only down side was that I had to get a spare wheel carrier for the rear but by doing that I retained the original main petrol
tank and that gave me 180 litres of
fuel capacity. half gas half petrol. Dual
fuel is the only way to go as you are not restricted to just the main centres as gas is hard to get the further out you go.
There is no telling what might happen with gas in the future so that is the only cloud on the horizon for a gas conversion.
At $10,000 cheaper for a petrol,
well that gives you a lot of coin left to put in the petrol
tank and you don't need to turbo them to get then to go.
Either way you go you will not be sorry, in my opinion.
Cheers, Bruce.
447914
