Oziexplorer problems - are there any experts on here to help me - please !
Submitted: Saturday, Mar 12, 2011 at 17:26
ThreadID: 84948 Views:2866 Replies:3 FollowUps:6
I have a small Toshiba Netbook and Ozi works fine on that, but I found the map on the screen covers too small an area, so I have bought a larger Toshiba laptop.
I have checked that the CONFIGURATION set up in both computers is the same (except for the PORTS), but I cannot get MOVING MAP to work at all on the new large one.
I have run the USB mouse driver installation and that made no difference.
There is 3 places where you can adjust the baud rate in CONFIGURATIONS - these are all set at 4800.
I adjusted the PORT numbers until I stopped getting messages that it was not connecting (or words to that effect)
I am off to Victoria for two weeks gold detecting tomorrow, so I would like to get it running before I go.
Any ideas how to get it going ?
Thanks a lot,
Willie
Reply By: Member - Stephen L (Clare SA) - Saturday, Mar 12, 2011 at 18:00
Hi Willie
I only ever use a baud rate of 4800 when I am using a GPS mouse. When I use a Garmin hand held GPS, the baud rate is 9600. If you can not find what is the correct com port, you can down load a com port checker from OziExplorer.
To do so, follow the following and you will be able to then set the rest of the configuration up correctly:
1. Log on to www.oziexplorer.com
2. Click on "Optional Extras"
3. Then click on Utilities and Extras.
4. Scroll down and click on the "GPS Port Checker"
5. Download the programme and run with the GPS connected to the laptop.
This will then tell you the correct Com Port to use for the type of GPS that you have connected.
I hope this helps you out.
All the best of luck and things should work fine.
AnswerID: 448011
Follow Up By: 3 - Saturday, Mar 12, 2011 at 18:52
Thanks Stephen, I will download it now and let you know how I went.
Willie.
FollowupID: 720371
Reply By: Member - Kiwi_In_Aussie(Wagga) - Saturday, Mar 12, 2011 at 18:48
It sounds to me as though you dont have the latest version of Ozi - from memory the last 2 updates come with a " Find GPS" function as part of the programme
Can I suggest you update to the latest version off the Ozi website and use the "Find GPS" button - it will tell you which comm port to use and the correct baud rate etc
Rgds
K.A
AnswerID: 448017
Follow Up By: 3 - Saturday, Mar 12, 2011 at 18:54
KA,
I purchased and downloaded the latest version for the new Laptop last night.
How do I find that on there, or does it find the correct port automatically ?
Thanks,
Willie.
FollowupID: 720373
Follow Up By: 3 - Saturday, Mar 12, 2011 at 19:08
I just had a look and I could not find a "Find GPS" button. Where is it ?
Thanks,
Willie.
FollowupID: 720377
Follow Up By: 3 - Saturday, Mar 12, 2011 at 19:24
I just found it in configurations. I will check tomorrow to make sure I am using the correct port.
Thanks,
Willie.
FollowupID: 720380
Reply By: Bonz (Vic) - Sunday, Mar 13, 2011 at 08:20
How'd you go Willie?
AnswerID: 448049
Follow Up By: 3 - Tuesday, Mar 29, 2011 at 17:41
Hey Bonz,
I failed to get it working before I set off for 10 days gold detecting at Castlemaine in the Golden Triangle.
I got back last night and am now checking emails. My plan is to ring GPS OZ and arrange for them to sort it out for a price.
I let my EO membership lapse.
Willie
FollowupID: 721970
Follow Up By: Bonz (Vic) - Tuesday, Mar 29, 2011 at 19:59
Willie, you might be able to tweak it to work. Whereabouts are you I am sure theres an EO member of affiliate who could help by taking a look at it
FollowupID: 722012
