Symplicity Suspension Wheel Hub Bearings
Submitted: Saturday, Mar 12, 2011 at 18:41
ThreadID: 84949 Views:6718 Replies:3 FollowUps:6
Getting ready for a 3 month trip around the NT and WA, so I was thinking of a few spares I might take, and Simplicity Suspension Wheel Hub Bearings could come in handy, what's that saying if you haven't got it you will need it, so does any body know what type of bearing they are?, the suspension is rated at 3500kgs, I googled Simplicity but not much info available.
Reply By: 3 - Saturday, Mar 12, 2011 at 18:45
I rang them in Adelaide when I needed info. Very helpful people.
AnswerID: 448016
Follow Up By: Member - DAZA (QLD) - Saturday, Mar 12, 2011 at 19:04
Thanks for the info 3.
FollowupID: 720375
Reply By: Gone Bush (WA) - Saturday, Mar 12, 2011 at 19:02
Daza,
just for info, if you think your van might need a wheel alignment when you get to WA, I just took my BT to Big Wheels in Forrestfield.
Excellent job.
AnswerID: 448021
Follow Up By: Member - DAZA (QLD) - Saturday, Mar 12, 2011 at 19:13
G/Day GB
I will put that in the Diary,allways handy to get a bit of local knowledge, I have had the wheels balanced just recently, it amazes me re: the amount of caravans around with unbalanced wheels.
FollowupID: 720378
Follow Up By: Gone Bush (WA) - Saturday, Mar 12, 2011 at 19:15
Daza, I'm sure you understand, balancing is different to alignment.
FollowupID: 720379
Follow Up By: Member - DAZA (QLD) - Saturday, Mar 12, 2011 at 22:23
GB
Yes I do, just had them balanced to make less wear on the running gear, no speed wobble.
FollowupID: 720389
Follow Up By: Member - Rob Mac (QLD) - Saturday, Mar 12, 2011 at 23:51
Hi Daza, I drive most of the time with drivers window down and on the motorways can tell when a vehicle comes up on righthand side with out of balance tyres, whop whop especially semi trailers after the prime mover has gone past,and mostly 4wd's with aggresive tread patterns.
Rob Mac
FollowupID: 720398
Reply By: jdbb - Saturday, Mar 12, 2011 at 19:31
Have a look here Daza - http://www.simplicityaxles.com.au/ - NP Hauffe site - there's a spare parts catalogue at the bottom of the list on the left hand side.
regards
AnswerID: 448024
Follow Up By: Member - DAZA (QLD) - Saturday, Mar 12, 2011 at 22:24
Thanks for the info John.
FollowupID: 720390
