Dometic Absorption Refrigerator RM 2350 in a 12' jayco starcraft.
Submitted: Monday, Mar 21, 2011 at 19:25
Member - Boo Boo (NSW)
G'day all
We recently purchased a 12 month old 12' starcraft and have travelled from
Scone to
Murgon without a problem.
On the weekend we went to the coast and noticed a few things that need some minor maintenance. No big deal.
However the
cook noticed that
the bench above the fridge was fairly hot. That did not appear to be right so I went on the net and found that the seala at the back of the fridge are probabley not vey good.
No problem I'll have a look tomorrow. What I have also noted is that the fridge seems to take a long time to get cold on 12v while driving. Is this normal?
Reply By: Rockape - Monday, Mar 21, 2011 at 19:50
Boo Boo,
they are slow on both 240 volts and 12 volts. I used to pull
mine down on 240 volts before leaving, then use 12 when travelling. I noticed the 12 volt fuse carrier was hot and when I measured the current it was 16 amps.
I then decided to pull it out and install an Engel 12/240 volt of the same size. When removing the top Dometic vent I noticed it was starting to melt from the heat of the gas exhaust.
Have a good trip.
448882
Follow Up By: Member - Boo Boo (NSW) - Monday, Mar 21, 2011 at 20:28
Thanks Rockape
I'll run the multi meter over it tomorrow.
We probably won't use the gas side of the fridge. So it did cross my
mine to put a 12/240v fridge in its place.
The vent will be off tomorrow and the setup checked out.
721147
Follow Up By: Rockape - Tuesday, Mar 22, 2011 at 06:21
Boo Boo,
you may have seen this before, if not then this will help with the cooling.
Fridge fan
721194
Follow Up By: Member - Boo Boo (NSW) - Tuesday, Mar 22, 2011 at 10:57
Thanks Rockape
I haven't seen that fan etc before.
I'm going to
Toowoomba on the weekend so I'll get the fan etc and see how I go.
721213
Follow Up By: Member - Boo Boo (NSW) - Thursday, Apr 14, 2011 at 17:45
G'day Rockape
I installed the fan to cool the fridge a few weeks ago, and thought it didn't work, but I walked past the vent yesterday and it does work!
So thanks for the photos and info very much appreciated. I thought I had done something wrong, but I obviuosly didn't go near the vent at the right time.
723888
Follow Up By: Rockape - Thursday, Apr 14, 2011 at 18:31
Boo Boo,
thanks for the reply, it brings back faith.
Glad to hear it works for you, it does make quite a difference
Look after yourself and those who are close to you.
723889
Reply By: Notso - Monday, Mar 21, 2011 at 19:53
Most of these fridges are not installed to the manufacturers instructions.
Most Van Makers leave a pocket of air above the fridge where all the heat from the heating unit gathers, this causes the heat you felt.
It can be removed by running a computer style fan to extract the hot air via the top vent.
These fridges are not as efficient on 12 volts and generally 12 volts is only good for keeping the fridge cool whilst traveling rather than trying to cool it down.
Having said that if you can, check the voltage at the fridge whilst it is on 12 volts and see what voltage is being delivered to it. You may find it isn't getting high enough voltage to work effectively.
You should have around 12 to 12.5 volts minimum. If you haven't it is probably the size of the wires from the battery to the fridge.
448885
Follow Up By: Member - Boo Boo (NSW) - Monday, Mar 21, 2011 at 20:31
Thanks Notso
The wiring and everthing else will get looked at tomorrow.
721148
Reply By: gjcumming - Monday, Mar 21, 2011 at 19:58
Hello Boo Boo
I have a 12' Jayco Expanda fitted with that fridge. If you remove the rear top fridge vent you will find an air gap over the top of the fridge where hot air is collecting. Stuff
the gap with insulation batt taking care not to interupt the hot air flow from the condenser on the rear of the fridge up & out the top vent.
As for the fridge 12 volt operation you may want to look at how the 12 volt is wired through you tow vehicle to the auxilary pin at the tailer socket. If its just regular thin auto wire then you may want to upgrade to thicker wire fused direct from the battery through a suitable relay tied to the ignition circuit. See an auto electrician.
Regards: Grant
448886
Follow Up By: Member - Boo Boo (NSW) - Monday, Mar 21, 2011 at 20:34
Thanks Grant
I know the wiring from the battery to the back of the troopy is good, so I'll look at the wire from the caravan plug to the fridge.
721151
Reply By: Member - Rob D (NSW) - Monday, Mar 21, 2011 at 21:31
My 3 way fridge has a label on the inside of the door stating that on 240V the power is 175 Watts and on 12V it is 125 Watts. 12V operation is only meant for keeping things cool while you are travelling.
I replaced my 3 way fridge with a 12V/240V compressor fridge.
I had a problem with my absorption fridge in hot weather and also if you stop to visit a museum for a couple of hours the 3 way fridge will switch off when the vehicle engine stops; that is unless you have one of the new 3 way smart fridges that change over to gas if other sources of power are not provided.
448896
Follow Up By: Member - Boo Boo (NSW) - Tuesday, Mar 22, 2011 at 09:51
Rob
We do stop and smell the roses, but we have a 100 amp battery that can run the fridge and from what I can gleam the fridge uses about 12amp per hour and runs continuously, which can be a concern.
I'm going to look at the van in a few minutes and see whats behind the vents.
I won't make a decision about changing the fridge just yet, but it may be a problem for us as we only use it for weekends or travelling to our work locations.
721203
Follow Up By: Member - Rob D (NSW) - Tuesday, Mar 22, 2011 at 10:44
Most trailer and vans have a relay that cuts power off to the fridge when the ignition is turned off. You probably need to check this out if you don't want to risk losing your food in the fridge.
721211
Reply By: Member - Boo Boo (NSW) - Tuesday, Mar 22, 2011 at 10:31
OK, I just took both vents off the back of the fridge.
At the top I can see the underside of the flat part of the sink. The only insulation was on top of the fridge, none above the black fins.
I also noted a black pipe with a 'T' bit on top. It was just sitting there, then I noticed it looked as though it would fit into the pipe going out the vent. It did so I pushed it into the 'vent' pipe.
I don't think it will solve the problem so I'll see if I can get a batt from a building site.
Next weekend I'll see if I can get the fan and parts from Toowooba and install that.
I'll keep you posted.
448933
Reply By: Member -Dodger - Tuesday, Mar 22, 2011 at 15:56
Boo Boo,
These fridges usually run better on gas, so if you are not connected to 240v and are stopped I strongly reccomend tahat you run the fridge on gas.
As said above start the fridge at least 24hrs before you want to use it and try to allways stack it with cold contents if you can.
These 3 way fridges are by no means the best performers but with adequate ventilation as said above and a little care they will do the job.
448957
