Dometic fridge on Gas
Submitted: Monday, Mar 21, 2011 at 20:22
ThreadID: 85151 Views:3148 Replies:4 FollowUps:5
Can anyone please give me a guide if we were to do some free camping, how many hours would a 186 litre Dometic fridge run on 4kg of gas on the lowest fridge setting?
Reply By: Hairs & Fysh - Monday, Mar 21, 2011 at 20:47
Depends on were you want to go and were are you.
Ask me next week when I get my new crystal ball, I'll be able to narrow it down for you. Just a tad more info will help.
A 90 lt 3 way will use about 360 odd grams of gas in a 24 hour period.
AnswerID: 448889
Follow Up By: i'machocoholic - Monday, Mar 21, 2011 at 20:55
ok - camped by the beach out of Exmouth, temperature 32-35 celcius, not much shade.
Does this help?
FollowupID: 721159
Follow Up By: Hairs & Fysh - Monday, Mar 21, 2011 at 21:03
Yeah it does.
Cause I'm on the East caost and if you were near I could give you a list of some around here, but you being over there I'm sorry i can't help.
Someone will be able to point you in the right direction.
Do you have a fan fitted to the rear of the fridge? cause this will help with blowing the hot air of the fins at the back. If you can shade that area of the van with shade cloth or something similar it will also help.
And make sure it is dead level in both directions.
These things sure help it run better.
FollowupID: 721164
Follow Up By: i'machocoholic - Monday, Mar 21, 2011 at 21:08
Hi Jon,
We have a fan fitted to the rear of the fridge, we've also had the cabling upgraded to thicker stuff - we've even got some shade cloth too. So we're trying to do all the right things. Thanks for the tip about ensuring it's level.
Thanks again.
FollowupID: 721165
Follow Up By: Hairs & Fysh - Monday, Mar 21, 2011 at 21:31
Being out of level is their biggest enemy.
On our Swan I have two levels fixed to the outside, one above the door and the other on the front just under the roff section. I get it within the marks on both, wind the top up, set it all up then I use a 6" level to check the fridge and make fine adjustments to get it as close as I can to level.
Have a look at the bottom of this page, Three Way Fridge Ventilation Upgrade they have put a fan inside the fridge as well to help.
Another thing, some people have said they have found mud wasp's nest of late in the chimney/exhaust of their their fridges, check to see if they haven't built a nest in yours.
FollowupID: 721166
Follow Up By: Ray - Tuesday, Mar 22, 2011 at 08:48
I have fitted a fan in my 3way. Just a normal 4" fan to the top grill but I have blocked the rest of the grill up so that the fan is the only exit for hot air but I have installed baffles all around the top evaporator. It works great. no themometer, no resister and the fan is held in position with bolts not cable tires.
FollowupID: 721199
Reply By: Member - Bill B1 (NSW) - Monday, Mar 21, 2011 at 23:21
I have a 40L portable Dometic that will run on a low setting in temps around 30'C for nearly two weeks on 4 kg bottle.
I did the test a few months ago so the memory is fading but it was close to this. I have not tested the 90L caravan fridge on a complete gas bottle but maybe you can extrapolate.
Bill
Bill B
AnswerID: 448910
Reply By: Ian & Sue - Tuesday, Mar 22, 2011 at 15:50
We have a 90 litre Dometic which runs off of a 9 kg gas cylinder - run in the WA - northwest (Wittenoon way) we get around 3 weeks which includes running the oven regularly for the cakes and running the stove-top every night for dinner and daytimes for cuppas. Our fridge is set between 3 and 4 setting just above the freeze the lettuce setting! Tip in the real heat is to cover the side of the van with the fridge with some shade cloth strung up from somewhere.
Sue
AnswerID: 448955
Reply By: i'machocoholic - Thursday, Mar 24, 2011 at 22:28
Thank you to everyone for your replies. We did some free camping for the past three days, and although hot with no shade (around 37 degrees daily), the fridge worked fine. Didn't put it on the coldest setting, but it did the job.
Thanks again.
AnswerID: 449169
