Sunday, Mar 27, 2011 at 21:47
Hi Sam & Lynne
I’ve have done the CSR three times in total, twice about two thirds of it and numerous smaller sections over the years getting to other
places, so have a lot of experience on it.
If I were to do it again I would allow a minimum of 21 days on the CSR, so you can take it all in, enjoy the serenity of the place and not punish your vehicle and tyres by rushing the trip.
Which way is best. I prefer N to S because, the dune approaches although a bit steeper aren’t as long or as dug out as the southern approaches and because that’s the way the cattle were taken i.e.
Kimberley to
Wiluna.
You also should bear in mind that if you start at the bottom in say mid August, you’ll get to
Halls Creek say mid Sept and it could be very hot. Doing it the other way will allow you to move south with the warming weather.
In addition if you come from N to S and suffer significant mechanical failure you’re closer to major towns to get help the further south you go.
I hope this helps.
721813
