Leaky 100 ser
Submitted: Tuesday, Apr 05, 2011 at 09:26
ThreadID: 85441 Views:2160 Replies:2 FollowUps:0
Was a thread a few weeks ago about this and one member Vk1dx had water coming in through the firewall.
Well a solution maybe that there is a hole in the left front, down reasonably low that the radio aerial goes through into the cabin. Has only a loose grommet on it and water would get in no trouble.
You have to remove inner guard plasticand mudflap to get at it.
Cheers Found it when fixing a minor ding in the guard.
Reply By: Member - Snoopy2 (NSW) - Tuesday, Apr 05, 2011 at 11:00
Hi Snoopyone,
Another cause is a blocked drain pipe from the Air Conditioner.
All the best,
Snoopy2
AnswerID: 450402
Reply By: vk1dx - Tuesday, Apr 05, 2011 at 17:01
I will check that out.
That was luck. Just about to close the PC down and make dinner.
I also stopped some other leaks around a bunch of cables that went through the firewall about half way down on BOTH sides.Well I at least I filled them just in case. I still have the carpet out as I haven't been in anything deep enough since last time we schatted about this. I also need to check the ventilation/heater system to make sure its not blocked or something.
Thanks Snoopy
AnswerID: 450422
