leaking deisel fuel tank holden rodeo.
Submitted: Thursday, Apr 14, 2011 at 15:15
big willy
I have a 2005 4x4 deisel and it leaks around the top of the
tank where the
fuel lines come out, any suggestions?
Reply By: Member - Serendipity(WA) - Thursday, Apr 14, 2011 at 17:25
You could take it to a professional workshop.
The easiest solution and cheapest is to seal the leak with metal cement
putty. I always carry some when travelling to fix
fuel tanks, radiators,
water tanks just about anything.
David
451254
Reply By: sheps - Thursday, Apr 14, 2011 at 20:54
G'day big willy,
We had a similar situation with our lux some months back and I repaired it with one of those twin coloured rolls of sealing
putty that you just slice a piece off and knead it into a consistant colour before applying.......sets within minutes; a great product.
Be aware you have to thoroughly degrease and remove any diesel residue from the area with a solvent. I had metho available and it worked a trick.
Good luck,
Sheps
451266
Reply By: big willy - Friday, Apr 15, 2011 at 07:39
thanks guys,
I think i will take it to the experts, it is hard to see exactly where it is coming from, but most likely the seal where all the fuek lines, wiring etc are attached.
451284
