Air Compressor Mounting
Submitted: Monday, Apr 18, 2011 at 21:51
Member - Barry H (WA)
Hi all,
I need some advice on the mounting of an air compressor (Blue Tongue).
I have a Nissan Pathfinder R51 which has very limited space under the hood, I had to mount the Dual Battery in the back of the truck, so space is at a premium.
I would appreciate any
views as to where I can mount the air compressor, the back is pretty
well taken up with a set of drawers and a fridge slide, so my options are limited.
I am not a big fan of things mounted underneath vehicles but I may not have any choice.
Barry H
Reply By: Member - Stephen L (Clare SA) - Monday, Apr 18, 2011 at 22:00
Hi Barry
If you do not have any room under the bonnet and have a set of drawers in the back of your vehicle, what about
the gap between the wheel arch and the side if the drawers? If you have a lift up panel, you would access to the compressor when needed, yet inside the vehicle and out of harms way.
Just a thought.
451729
Reply By: Member - beergutz - Monday, Apr 18, 2011 at 22:36
Hi Barry H my ABR comp is under drivers
seat in my Patrol cab chasis
Cheers Bruce
451733
Reply By: Member - Steve & Cecily W (QLD - Tuesday, Apr 19, 2011 at 06:11
If you check out www.pcoa.org.au (pathfinder's club of Au) there's heaps of info available on their
forum. Lack of space under the bonnet means quite a few mount theirs under the driver's
seat.
451745
Follow Up By: Member - Barry H (WA) - Tuesday, Apr 19, 2011 at 09:23
Thanks for all those suggestions I will investigate which one suits best, once again thanks.
Barry H
724384
