toyota 60 series rear output shaft oil seal
Submitted: Monday, Apr 25, 2011 at 18:35
ThreadID: 85859 Views:2149 Replies:1 FollowUps:3
Any body know where I can get hold of a toyota 60 series rear output shaft oil seal ,regards Stephen.
Reply By: Member - Toyocrusa (NSW) - Monday, Apr 25, 2011 at 18:52
Hi. Stephen. I would only use a genuine Toyota seal. Make sure the shaft yolk seal dia. is in good condition and not too much movement is in the output shaft. Cheers,Bob
AnswerID: 452288
Follow Up By: stephen humphrys - Tuesday, Apr 26, 2011 at 00:33
Ok Bob, by the yoke seal you mean the bit on the companian flang shaft that protects the oil seal ,regards Stephen.
FollowupID: 724984
Follow Up By: Member - Toyocrusa (NSW) - Tuesday, Apr 26, 2011 at 09:09
I meant the diameter that the seal runs on. Make sure it does not have a noticeable groove left in it from the old seal. A shallow groove or shiny surface would be acceptable. Cheers,Bob
FollowupID: 724996
Follow Up By: stephen humphrys - Tuesday, Apr 26, 2011 at 17:57
I,m with now, thanks a lot again Bob regards Stephen.
FollowupID: 725050
