TOYOTA LANDCRUISER 80 SERIES GXL 90 MODEL
Submitted: Tuesday, Apr 26, 2011 at 13:48
ThreadID: 85869 Views:3960 Replies:4 FollowUps:6
When taking off from standstill it jumps out of high gear but will drive in low gear. Just wondering if anyone has any ideas.
Reply By: SPRINT-GTO - Tuesday, Apr 26, 2011 at 13:57
Ian
Suggest you try the LCOOL forum(Landcruiser Owners Online ) there are a heap of knowledgeable persons on this forum who may be able to steer you right
Good Luck
Gary.
AnswerID: 452346
Reply By: IAN S5 - Tuesday, Apr 26, 2011 at 14:01
cheers Gary
AnswerID: 452347
Reply By: Member - Tour Boy ( Bundy QLD) - Tuesday, Apr 26, 2011 at 15:12
Make sure that you have no mud etc built up around the transfer case lever stopping it from moving fully into the high range position just enough to make it jump out under load. Or possible a broken mount causing the gearbox motor to flex bumping the shaft out of gear.
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 452358
Follow Up By: IAN S5 - Tuesday, Apr 26, 2011 at 16:42
Hi Dave
No mud/dirt built up and engine mounts and gear box mounts are fine.
Ian
FollowupID: 725037
Reply By: Member - Rob S (NSW) - Tuesday, Apr 26, 2011 at 16:09
Not real clear on your description.
Is the gear box jumping out of gear or the transfer case?
How many klm's are on the gear box.
Being a 90 model i suspect a few klm!
I you are talking about not jumping out of gear in low range, ie less load on the gearbox, thus not jumping out, it will probably still jump out in low if you give it a bit of stick.
More than likely time for a gearbox overhaul.
Rob
I only ever made one mistake
AnswerID: 452366
Follow Up By: IAN S5 - Tuesday, Apr 26, 2011 at 16:40
Hi Rob
jumping out of high in the transfer case when you start from a standing start.
Did it a couple of times now does it all the time.
But will drive alright in low gear no matter what speed.
450k on the clock.
FollowupID: 725036
Follow Up By: Member - Rob S (NSW) - Tuesday, Apr 26, 2011 at 17:37
Hi Ian
Can't help you much there,more than likely something worn with those klms.
Try draining the oil to see what bits and pieces come out?
Unless it is something with the electric motor selector unit, probably have to remove the transfercase to inpect all that properly?
The transfer case can be removed from the gearbox in place in the vehicle.
How are the syncros in the gear box i know mine are stuffed at 220k.
And grates between 3/4th, fairly common.
With 450k guess it would be time for an overhaul?
Rob
FollowupID: 725048
Follow Up By: IAN S5 - Tuesday, Apr 26, 2011 at 18:26
Hi Rob
thanks for that = hardly ever used the 4wd high and low box. I did drain the oil not metal in the sump plug and also drained transmission oil and no sign of any metal, the gear box changes gears fine with no grating/noises just the high and low gear lever jumping out of high as you go to move off.
looks like I will have to pay someone - any recommedations?
thanks for your feedback
Ian
FollowupID: 725052
Follow Up By: Member - Rob S (NSW) - Tuesday, Apr 26, 2011 at 18:46
Can't recomend anyone only the yellow pages . And as Gary said you could try landcrusier owners online could be worth a look.
http://www.lcool.org/about.html
Rob
FollowupID: 725054
Follow Up By: IAN S5 - Tuesday, Apr 26, 2011 at 19:21
Yes I took Gary's advice and registered but have to wait up to 24 hours to be accepted.
Thanks for taking the time to respond.
Ian
FollowupID: 725061
