Penrite diesel SP?
Submitted: Thursday, Apr 28, 2011 at 19:50
ThreadID: 85933 Views:2878 Replies:5 FollowUps:8
Has anyone used this oil yet?
If so what's the verdict, good or not?
I have 200,00k on my 05 TD Courier and it has been recommended to me, so if you know anything about it would like to hear your thoughts as I have used Penrite for years.
Bushy.
Reply By: Direct Four WD Awareness - Thursday, Apr 28, 2011 at 20:14
Its gota be good if it meets the specs of your vehicle.
wouldnt use anything else
AnswerID: 452619
Follow Up By: Member Bushy 04(VIC) - Friday, Apr 29, 2011 at 08:31
I did not say that it was bad. All That I was after was has anyone used it yet, I have used Penrite for over 15 years however am not impressed with the Diesel 5 usage.
!.5ltr in 10,000k , have never had a usage rate anywere near that over that time frame.
Thanks anyway.
FollowupID: 725375
Reply By: BrownyGU - Thursday, Apr 28, 2011 at 23:51
Bushy,
I have used Penrite oil in my 04 GU 4.2 TDI since new, it has done 267,000km, of mainly hard yacka towing a heavy tandem trailor around Melbourne for work, wich involved plenty of short, stop start trips etc, and allways towed a boat or camper for holidays, and it is still A1, I have no hesitation in recomending Penrite.
Cheers.....Browny
AnswerID: 452666
Follow Up By: BrownyGU - Thursday, Apr 28, 2011 at 23:52
P.S. Chainged every 5000k and filter every 10,000km
FollowupID: 725355
Follow Up By: Member Bushy 04(VIC) - Friday, Apr 29, 2011 at 08:36
Cheers Browny, have used it ever since I worked in an engine shop and seen the difference it made.
This new Diesel SP has been recomended to me, and I did not even know of its existance so I was trying to see if anyone else has heard of it.
Cheers Bushy.
FollowupID: 725377
Follow Up By: BrownyGU - Friday, Apr 29, 2011 at 12:09
Cheers Bushy,
Sorry didn't quite get the SP bit, but still not the most useless responce you've had.....:)
Browny
FollowupID: 725406
Reply By: get outmore - Friday, Apr 29, 2011 at 03:16
best stuff yet
been running it for 2 oil changes now 10,000 ks and havnt needed a single rebuild - no meltd pistons, nothing
seriosly wht sort of nswer were you after?
some guy reckons hes done 260000 whtever ks uing xxxx oil fstidisouly
so what?
ive got well over 300000 first 200 who knows wht it had - it had no sevice history and was fleet vehicle
last 11o or so ive fed it wht ever ws chepest from shell to valvoline to castrol etc
AnswerID: 452673
Follow Up By: Member Bushy 04(VIC) - Friday, Apr 29, 2011 at 08:41
Point taken but had you heard of Penrite SP before..
As previously stated used to work in an engine shop so oils ain't oils.
Bushy.
FollowupID: 725378
Follow Up By: Member - Phil G (SA) - Saturday, Apr 30, 2011 at 20:26
I have to agree with get outmore. Diesels engines go forever using any brand of oil, as long as you change it when needed.
I never use Penrite - too much hype in their advertising.
What does SP mean? is it the API grade after SM?
FollowupID: 725612
Follow Up By: Member Bushy 04(VIC) - Sunday, May 01, 2011 at 08:52
Hi Phil Penrite Diesel SP is a new oil for the SAE 10-40 range, as there earlier oil did not seem to suit certain vechiles.
It has been out since maRch 2010, but no one seems to have heard of it?
Bushy.
FollowupID: 725639
Reply By: Member - Johny boy (NSW) - Friday, Apr 29, 2011 at 09:39
Hi Bushy, I use penrite semi Synthetic 15/50 in my 98 mod 100 ser L/C diesel it has an A/M tubo and has just hit 330,000 I change the oil every 5000km and I also change the filter ( for $30 I cant understand the point in running the rubbish I have been filtering for the last 5000ks back through with new oil?) but thats just my thoughts
Cheers.
AnswerID: 452700
Follow Up By: Alloy c/t - Sunday, May 01, 2011 at 09:30
Got to agree , what and where is the point of running fresh oil thru a dirty filter , once the oil needs changing so does the filter ,
FollowupID: 725641
Reply By: member - mazcan - Sunday, May 01, 2011 at 12:51
hi bushy 04
i have not heard of sp penrite
but i have been changing engine oils for the last 50yrs + and have used just about everybrand on the market for various long periods and what i have learnt and found is
its how regular the oil and filter is changed more so than the quality that really counts
despite all the lastest long term recommended oil change periods by car makers
i still stick rigidly to 5000km oil and filter changes their long term gimmicks is designed to wear out engines and sell more parts and /or vehicles
imho
cheers barry
AnswerID: 452909
