Dometic RM22553 240v Problem
Submitted: Friday, Apr 29, 2011 at 12:18
Bourbah
My Dometic RM2553 suddenly stopped working on 240 volts while 12v and gas are still perfect. The power is still getting to the terminal block at the back of the fridge, from there I assume it must be the element.
Please could someone give me directions how to locate the element. From what I read it can be replaced by a handy man without removing the fridge.
A website with wiring diagrams and a pinpoint location of the element would be great.
Thanking someone in anticipation,
Reply By: Hairs & Fysh - Friday, Apr 29, 2011 at 14:01
Hi John,
Is there any anything here that maybe of help to you?
Dometic Refrigerators
Jon
452730
Follow Up By: Bourbah - Friday, Apr 29, 2011 at 16:47
Jon,
Thanks for your reply.
What I guess I'm after at the moment is information as to where the 240v element is actually located in the fridge. If I can gain access to it without removing the fridge then I can run a multi meter across it and replace if necessary.
725436
Follow Up By: Hairs & Fysh - Friday, Apr 29, 2011 at 17:01
Depends I guess John on how big the panel is to gain access to the rear from the out side of the Van.
I'm having a guess here that they wouldn't be a great deal of difference to an older RM360, the element is placed in the flue section. I have had a 150W element for the 12V installed and I believe they are beside the 240V element.
Have a look here
RM360 Page 13.
This may give you some help.
Jon
725440
Reply By: Ianw - Saturday, Apr 30, 2011 at 19:59
Try this
tech data
Note. Refers to US 120 volt element for resistance readings
Ian
452858
