Jerry can drip tray?
Submitted: Tuesday, May 03, 2011 at 15:18
ThreadID: 86046 Views:2353 Replies:3 FollowUps:2
Can you get a tray or some thing like it to fit jerry cans in? On your recent trip diesel dripped down the side of them now it is every where in storage box plus that lovely aroma.
If not I will probably make one. Will need to take three jerry's.
Col
Reply By: Member -Pinko (NSW) - Tuesday, May 03, 2011 at 16:27
Col
You need to fit new gaskets to the jerries.
AnswerID: 453164
Reply By: happytravelers - Tuesday, May 03, 2011 at 21:39
I agree with the above, the Jerry cans should not have leaked in the first place. If they are the metal ones, fit new seals to the cap, they're available at most auto/camping shops.
On my last trip I carried diesel in metal Jerry cans in the campers tool box sitting on they're sides, no spillage problems at all.
Jon
AnswerID: 453213
Follow Up By: Col WA - Wednesday, May 04, 2011 at 00:04
Hi , they are plastic containers no seals on pouring spout just a taper seal, which did not work to well so would leak down the side causing the problem .No matter how well you wiped it off after.
Will try making a sheet metal tray, if no good will try to find some good second hand metal ones.
Col
FollowupID: 726002
Reply By: dazza62 - Tuesday, May 03, 2011 at 22:01
Got mine from Black Widow. Came in a choice of two or three jerry cans.
AnswerID: 453216
Follow Up By: workhorse - Wednesday, May 04, 2011 at 18:02
I use those rectangular recycling tubs that everyone had before the Otto bins. I picked up quite a few from friends in SYdney when the change over happened .
I can fit 3 plastic jerry cans in nice and snug in them. Used them for a while in the back of the ute and they work well.
FollowupID: 726062
