fujitsu ten stereo
Submitted: Sunday, May 08, 2011 at 10:40
Pat 105
i am trying to fit a fujitsu ten stereo to my 105 series landcruiser 2002 model, the stereo seems to be ten mm to wide on both sides
do you have to cut the panel or is there a panel from a different model that will fit ?
ime not real keen on cuttinng my panel. i think it would look rather tacky !
pat 105
Reply By: Member - Doug T (NT) - Sunday, May 08, 2011 at 10:52
a few weeks ago we fitted a new radio in the Station Triton , it was in a sort of a mounting cradle in the box, we had to remove the radio from that cradle before it would fit in the space in the vehicle. then just throw the discarded cradle in the bin.
453607
Reply By: snoopyone - Sunday, May 08, 2011 at 12:43
Toyota stereos are rebadged Fujitsu so you must have the wrong model for your car
453611
Follow Up By: snoopyone - Sunday, May 08, 2011 at 12:48
The later model in a 100 ser is 08600-00988 or 08600-00989 and is quite
different to the 2002 dashboard
It has a rounded face and is a funny
grey color and the older one is flat and black
726457
Follow Up By: Pat 105 - Monday, May 09, 2011 at 01:01
cheers snoop, i will try the local toyota wreckers and see if i can get a center panel ti fit,
pat 105
726515
Follow Up By: Pat 105 - Wednesday, May 11, 2011 at 19:47
well i found out from my toyota dealer that the 2002 cruisers have two different models, ser 1 and ser 2, ser 2 came out november 2002 and have a totaly different center dash panel,
snoop was right,
cheers pat 105
726811
Reply By: Member - Col G (WA) - Sunday, May 08, 2011 at 14:17
Have you removed the whole centre assembly, it sounds not. Once that is removed you mount the radio behind in its cradle either single din or double din and replace the facia in front of it.
Hope it helps.
Cheers Col
453618
Reply By: snoopyone - Sunday, May 08, 2011 at 15:40
Join up at Lcool
forum and do a search on Radio installations.
Should tell you how to do it.
Do the search They get upset it its there and you dont.
According to the manual you have to remove the surround and fit the radio and put the faceplate back over it.
It will have illustrations on Lcool on how to do it.
There are 4 clips to undo to get it out two are just above the outer edges of the radio and two are just above the centre level of the air controls.
You will need a body clip separator or a thin knife to disengage them
453621
