Fitting HF radio.
Submitted: Monday, May 09, 2011 at 11:28
ThreadID: 86153 Views:3827 Replies:6 FollowUps:1
Good morning all,
I have purchased a Barrett 2050 radio complete with auto tune antenna.I intend to install it in my gu patrol.Can anyone offer any advice on the best way to install this.The autotune antena i would like to locate on a bracket on the back door.I believe you can purchase a special bracket for this purpose.I live in Mandurah WA so anyone know where i could purchase a bracket close to home.Any advise on the installation would be a great help.
Reply By: Polaris - Monday, May 09, 2011 at 11:42
Go and see Barrett - they are in Perth. Probably every chance they have a bracket to suit your GU.
AnswerID: 453703
Reply By: Mr Pointyhead - Monday, May 09, 2011 at 12:01
You want one of these:
Kaymar HF Aerial Mount for factory tyre carrier
AnswerID: 453707
Reply By: Voxson - Monday, May 09, 2011 at 14:48
Make sure you use the huge fuse which is supplied with the unit.
Also make sure you run the antenna cabling and the power cabling down seperate sides of the vehicle to reduce interference.
The antenna joiner needs to be out of the weather, inside the vehicle is a nice dry place.
AnswerID: 453722
Reply By: Stu & "Bob" - Monday, May 09, 2011 at 17:27
Earthing, earthing, earthing. Make sure there are good earths.
AnswerID: 453740
Follow Up By: Member - Phil G (SA) - Monday, May 09, 2011 at 17:55
Yes....and its worth noting that the door itself is not a good earth.
If Dennis were to use one of the door hinge bolts that attach the rear door hinge to the vehicle's body, then he'll have the best earth.
FollowupID: 726586
Reply By: blue one - Monday, May 09, 2011 at 20:03
Dennis,
Electric Bug (SA) sell a bracket that mounts between the rear large barn door and the tyre bracket. It will carry a Barrett or Codan auto.
It's a good unit and it has served me well.
As noted earth everything on your vehicle, doors to body, bonnet to body, body to chassis and a very important aerial earth to the chassis.
I followed this advice from a very nice bloke on this forum years ago which has allowed me very good comms all over Aus.
Make sure you run the power and control cables to the aerial on opposite sides of the vehicle.
Let me know if you need anymore assistance.
Steve
AnswerID: 453765
Reply By: Member - Dennis F (WA) - Tuesday, May 10, 2011 at 06:53
Thank you to everyone who has taken the time to answer my question,it has been a big help.
AnswerID: 453808
