Lock Tab failuure on 100s front wheel bearings?
Submitted: Monday, May 09, 2011 at 19:19
ThreadID: 86171 Views:3360 Replies:6 FollowUps:5
Anyone experienced this?, ..Mine had near sheared off letting the adjusting nut to loosen up,both nuts could have wound right off in time if i had not heard the clonking ,...nice one...lol.
Cheers Axle
Reply By: Lex M (Brisbane) - Monday, May 09, 2011 at 19:28
Have the bearing been serviced and the lock tabs reused, not replaced?
AnswerID: 453755
Follow Up By: Member - Tour Boy ( Bundy QLD) - Monday, May 09, 2011 at 19:30
That would be the problem, if you reuse the lock tab you usually end up re bending the same tab and they can shear off. Lucky the bearings only came loose, the broken off tab can destroy the bearings.
Dave
2015 Fortuner
Had 72 cruisers in my time
FollowupID: 726599
Follow Up By: Axle - Monday, May 09, 2011 at 20:30
I have not touched the front bearings since owning the vehicle, (2yrs),,,going by service schedule they are due to be replaced at 200.000ks which it has just turned over, Supposingly been dealer serviced every 10,000ks...someone didn't get it right at some stage maybe.
Cheers Axle
FollowupID: 726608
Follow Up By: get outmore - Tuesday, May 10, 2011 at 16:15
couldnt swear to a 100s service schedule but other tojos they are a 40k service item
(ie 40,80,120 etc)
my ex had them stuffed up after the 40k service and
KALAMUNDA TOYOTA
denied all knowledge until it was pointed out they did the 40k service no one else would have touched them and the vehicle had had nothing but gen toyota sevicing
funny seeing their faces when they wriggle as hard as they can but end up against the wall with no option but to pay all repairs
FollowupID: 726669
Reply By: Member - Phil G (SA) - Monday, May 09, 2011 at 19:49
Locking tabs need to be replaced as part of wheel bearing maintenance. They cost next to nothing.
AnswerID: 453761
Reply By: Member - Toyocrusa (NSW) - Monday, May 09, 2011 at 19:53
As the others have said Axle, a new tab washer. The both nuts should also be torqued up with a correct fitting socket. If the lock nut is not tightened correctly it will allow both nuts to move. Cheers,bob.
AnswerID: 453762
Reply By: Michael ( Moss Vale NSW) - Monday, May 09, 2011 at 19:57
Axle!!
That must have been the passenger side, lucky it wasnt the drivers side where it could have locked up the wheel, unless of course it has a Left hand thread.. Michael
AnswerID: 453764
Reply By: Whirlwinder - Monday, May 09, 2011 at 20:36
Axle,
I had one fail ( don't remember why it failed) and the two nuts screw off allowing the wheel and hub to be retained only by the disc brake being trapped in the caliper.
It was driving normally and I only noticed something was wrong when I saw a pool of oil/grease on the ground at a morning tea stop.
A careful trackside repair then a drive to Cohen to get the bits to repair it properly.
It was an old 60 series and that was to only thing that ever gave me grief.
Ian
AnswerID: 453770
Follow Up By: StormyKnight - Tuesday, May 10, 2011 at 15:49
Sounds all to familiar, but for me it was the rear passenger side on the 60 & drum brakes so this allowed the whole wheel & floating axle to move out from the car....
We were just south of the Jardine heading south, but had to jerryrig a large log under that corner of the car & put the axle & wheel up on the roof. We got about 10km & eventually the mechanic from Bamaga arrived & got us on the road again.
All good fun though!
FollowupID: 726667
Reply By: Off-track - Monday, May 09, 2011 at 23:16
Whilst changing the locking tab is undoubtedly good maintenance and should be done, it is not necessarily a must do. If an unused tab is able to be used upon reinstallation then there is no detriment to its effectiveness.
However as stated they are cheap and if the task is planned then new washers should certainly be used.
AnswerID: 453798
Follow Up By: member - mazcan - Thursday, May 12, 2011 at 15:36
hi offtrack
couldn't agree more no matter what vehicle it is
yes as you said if the adjusted bearing finishes with the nut at a different lock -tab it is quiet ok to use the new one
but never try and re-use one as they will and have been known to break off
some vehicles have lock plates that are secured by phillips head screws which i have found to be a much superior system
ford /mazda and if memory serves me nissan navara
cheers barry
FollowupID: 726914
