improve performance
Submitted: Wednesday, May 11, 2011 at 16:38
Member - Noel C (NSW)
Hi Guys,
I own a 2004 (IFS) factory turbo diesel 100 series landcrusier.
It,s just clocked up 150K. As a consequence the timeing belt needs replaceing and I beleive Toyota also reccomends the injector pipes get replaced at 150K as
I am loking to have a full service which incorporates the above. I,m also looking to fit a chip and new exhaust.
To all those mechanical minded out there I like to know what you would recommend I do in what order and what brand chip and exhaust would you recommend?
I,m been quoted about $1800 just for the full service etc thats before I fit a chip and exhaust.
Reply By: snoopyone - Wednesday, May 11, 2011 at 16:56
Bet the service doesnt inlude the injector pipes.
I had my 150,000k service done a while ago and it cost me $1200 including the timing belt and idlers which were over $50 each.
Didnt do the pipes as havent heard of anyone doing them.
A chip and an exhaust will cost about $2500.
I had
mine done at AMMS in
Brisbane Cost $1000 roughly for a 3" mandrel exhaust and I had a chip I got off Ebay.
Thye sell RAPID chips and they are between $1200-$1500
Good outfit and good service
Get a
Beaudesert Exhaust (NOT STAINLESS $1800+)
453974
Reply By: Member - John B2 (VIC) - Wednesday, May 11, 2011 at 17:08
Had my 150k service done last week by a
well respected 4wd Specialist in
Melbourne, as Mick O will agree ATOC
Did not changed injector pipes, but did replace timing belt, hydraulic tensioner and timing belt adjuster bearing (genuine parts).
Total Cost under $ 700.
2001 Landcruiser 100 Series Turbo Diesel
453976
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 17:22
You did
well Toymota charged me as follows
140,000k service $434
Tensioner $106
Timing belt $71.33
Idler $109.09
Plus other bits and oil
$414 labour for service
$234 for belt change
Total cost$1192.35
Done at Toyota
Coffs Harbour
726793
Follow Up By: Member - John B2 (VIC) - Wednesday, May 11, 2011 at 17:31
Parts for service and timing belt $ 544.68
Labour 2 hours @ $ 75 = $150
My local Toyota dealer wanted $1200
726795
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 17:36
Good but
mine was 140,000 not 150 as I thought and the hubs and brake fluid and diffs etc had to be done as
well so was 4 hours for that plus the belt
726797
Follow Up By: Member - John B2 (VIC) - Wednesday, May 11, 2011 at 17:47
I can now see why your service was so dear, as you have done the 140k, 150k and 160k service all at once.
Probably cheaper in the long run good thinking!!
726799
Follow Up By: River Swaggie - Wednesday, May 11, 2011 at 17:59
"Done at Toyota Coffs Harbour"
Hiya Snoop...."Does that mean Once Bitten Twice Shy"
726800
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 18:11
No not unhappy
726803
Follow Up By: Member - John B2 (VIC) - Wednesday, May 11, 2011 at 18:28
Glad your not unhappy and Toyota
Coffs Harbour is very happy :-)
726804
Reply By: Mick O - Wednesday, May 11, 2011 at 19:59
Noel,
I’ve done a bit of research on this and am fitting a 3.5 inch Taipan system and a rapid chip next Tuesday. I’m having it fitted at a diesel specialists up in the northern suburbs. I went for the Taipan having seen them at one of the 4x4 shows and they were very accommodating in customising
mine to allow for the stretch, long range
tank and all the undertray boxes.
As far as the chip is concerned I’ve chosen the Rapid following a couple of reviews and speaking with a few diesel experts. The rapid is a
fuel pulse type module and is completely tuneable as opposed to the simpler plug and play modules. It takes a lot of dyno time to set it up for my needs factoring in the exhaust. I will be able to provide you with more in respect to performance and power gains in a couple of weeks (and the prices as
well....yikes!)
Cheers Mick
453996
Follow Up By: Mick O - Wednesday, May 11, 2011 at 20:00
P.S. With the exhaust on the cab chassis units, they reccomend fitting an EGT guage so I'm having that fitted at the same time.
Ka ching!$!
Oh
well, I don't waste it on wine women and song!
726813
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 20:18
Very wise Mick Its a very worthwhile addition
726817
Follow Up By: Member - Noel C (NSW) - Wednesday, May 11, 2011 at 20:39
Ok so what does the gauge do for you?
726823
Follow Up By: snoopyone - Wednesday, May 11, 2011 at 20:54
All explained in thread 86187.
726826
Follow Up By: Mick O - Wednesday, May 11, 2011 at 21:18
As these chips are designed to get extra
fuel to the engine, the end result is more heat being created. Not keeping an eye on it can push a motor into the death zone if one's not careful. Part of my reasoning in going with the rapid is that the chip can be tuned where as many of the plug and play modules simply rely on getting extra
fuel dumped into the motor.
The EGT will let you know what's happening with heat in the engine as opposed to relying on vehicle temp gauges that rely on
water jacket temperature and react quite slowly.
726835
Follow Up By: Member - Noel C (NSW) - Monday, May 16, 2011 at 14:54
How did the Taipan go"?
What EGT gage did you have fitted?
727302
Reply By: Alex C - Wednesday, May 11, 2011 at 21:58
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule
Forum Moderation Team
454014
