tyre pressure
Submitted: Saturday, May 14, 2011 at 18:25
ThreadID: 86276 Views:2898 Replies:6 FollowUps:6
What pressure would be good for development road to cape york? We have coopers stt's on our vehicle. Ta Ally
Reply By: Member - John B2 (VIC) - Saturday, May 14, 2011 at 18:27
What sort of vehicle are you driving.
AnswerID: 454259
Reply By: Shaker - Saturday, May 14, 2011 at 18:52
Try dropping around 10psi from your road pressures & then adjust from there.
Did you say Cooper STs? Take plenty of spares!
AnswerID: 454264
Follow Up By: Member - Duncs - Saturday, May 14, 2011 at 18:59
Shaker,
I am on my third set of ST/C,s without a puncture or tyre problem.
Duncs
FollowupID: 727101
Follow Up By: allyson52 - Saturday, May 14, 2011 at 19:03
The tyres are stt's Ta Ally
FollowupID: 727102
Follow Up By: Member - Mark G Gulmarrad - Sunday, May 15, 2011 at 12:41
grinding that same old axe again are we Shaker?
YAWN.................
FollowupID: 727166
Reply By: Member - Duncs - Saturday, May 14, 2011 at 18:58
Allyson52,
I have a system for determining tyre pressures. I call it the 25% rule.
I work on 4 types of road conditions highway, good dirt, rough dirt/fire trail and soft sand.
I run about 44psi on the highway. When I go onto good dirt I drop my tyre pressure by about 25% so in this case 10 or 11psi. They are now about 32 to 34psi. I can still travel at reasonably high speeds but it is a bit easier on everything.
When the road deteriorates again, rough fire trail kind of thing, I drop tyre pressure by 25% again. This time it is about 8 tto 10psi so the tyres end up at about 24psi. At these pressures I don't often get over 80k/h but the road usually determines that.
When I leave the fire trail and hit the soft sand, like Simpson Desert or Stockton I drop the tyre pressure by about 25% again. This time it is about 6 or 7 psi so they end up at about 18psi. Once again I modify my speed as a concession to the conditions and the tyre pressure.
Now this is a guide not a strict rule. so these are just starting points. I will adjust pressures depending on how they feel.
This works for me and helps me to work out what sort of pressure I need based on what the road is like when I arrive.
Feel free to use this system, modify it or simply ignore it
Duncs
AnswerID: 454265
Follow Up By: Wayne (NSW) - Saturday, May 14, 2011 at 19:09
Duncs,
That 25% rule is a very good starting point for tyre pressures.
I run about the same pressure as you have suggested but I normally only go as high as 40psi for highway running.
The tyre pressure that anybody uses is only as good as the tyre pressure gauge that is being used so it is very important to adjust tyre pressure if the tyres are not performing as they should.
Wayne
FollowupID: 727103
Reply By: allyson52 - Saturday, May 14, 2011 at 18:59
a 2002 holden rodeo xtra cab
AnswerID: 454266
Reply By: Member - Stephen L (Clare SA) - Saturday, May 14, 2011 at 19:12
Hi Allyson52
Start at 20% lower than your standard highway pressures. With the reduced tyre pressures will also come a reduction in speed.
AnswerID: 454267
Follow Up By: Frances - Saturday, May 14, 2011 at 21:37
I travelled on about 26lb in my Patrol but if you slow down you will feel every bump. You need to travel at about 100kph to sit above the corrugations (but just be careful you don't get bumped across the road when going around bends!)
FollowupID: 727117
Follow Up By: Rockape - Sunday, May 15, 2011 at 07:37
Stephan,
good advise re the speed, I hope others realise that travelling at highway speed on reduced tyre pressure lets the sidewalls flex a huge amount and in turn produces lots of heat and eventually a blowout or de lamination.
Frances, I hope it is not you coming the other way on a bend and you are dancing across the road straight at me.
For the original post her are my pressures on 285/75/16 tyres which give me a high load rating.
Unloaded around town - 30 to 35psi.
Loaded (3000kg) on bitumen - 35 to 36psi front and 40psi rear.
Good dirt loaded same as on bitumen.
Corrugation's loaded. - 28psi at 80kph max, then I drop them more as
road or track deteriorates with a reduction in speed.
For example, if I drop them to 22psi I will only be
travelling around 30kph.
Hope this helps
RA.
FollowupID: 727133
Reply By: Member - Bucky - Sunday, May 15, 2011 at 09:32
allyson
40 in the black stuff
22-25 on gravel roads ( most outback roads ) and never over 70km/hr
12-15 in sand or rough tracks.....never over 40 km/hr
22 - 25 is my most used pressures, no matter what weight my Patrol is !
Bucky
AnswerID: 454321
