Nissan Accessories
Submitted: Tuesday, May 17, 2011 at 11:05
Member - Desert Storm (QLD)
I am looking around for front recovery hooks to suit an '06 Nissan Patrol. They are like hens teeth!
Does anyone know of an online accessories site that has these type of hooks? the OEM that comes with the it is the open ended type. I would prefer to have them closed in.
thanks in advance,
Reply By: Gossy - Tuesday, May 17, 2011 at 11:18
rare? Any 4wd
shop supplies these (hooks and loops).
454545
Follow Up By: sweetnam - Tuesday, May 17, 2011 at 11:47
Yep
ARB, TJM and others sell a big red plate that bolts on where the bullbar mounts to the chassy. Has a closed look for a shackle - about $60 if I remember
B
727403
Follow Up By: Dave(NSW) - Tuesday, May 17, 2011 at 15:39
I tried ARB & TJM and was told they had never heared of them, I brought
mine on line from some place in SOUTH AUS FOR $90 a pair
Image Could Not Be Found
Cheers Dave
727446
Follow Up By: Member - Desert Storm (QLD) - Tuesday, May 17, 2011 at 15:53
thanks for all your input guys. I have seen the plate type on line, but i wont be able to fit it. the driver's side has the OEM open hook mounted on the underside of the chassis rail, and above that there are the three holes to take the plate type. now on the off drivers side, the three holes exist, but without threads in them so i wont be able to mount a plate on that side. my option is to find a closed type hook that has the holes spaced out the same as what is on the underside of the chassis rail. both rails on my car have the threads cut out to take the hook type, but i have tried a couple of hooks and had to take them back because the hole spacings are narrower than what is on the chassis rail.
727450
Follow Up By: Gossy - Tuesday, May 17, 2011 at 15:57
walk into the shops of TJM, ARB or Opposite Lock. They're web pages don't have them on (ARB do show the hook type) but they do sell them off the shelf though.
727451
Follow Up By: Member - Michael and Chris (QL - Tuesday, May 17, 2011 at 19:17
I have a GU 1V and have found that the Outback Ideas option does not fit, they will fit earlier models but not
mine so I am still looking also. Cheers Mick
727491
Follow Up By: Member - Desert Storm (QLD) - Sunday, May 29, 2011 at 00:11
hey mick,
have you managed to find anything to fit your rig to use a recovery point? i have been in touch with a few people, and they agree with me that the plate will not fit on my model as the three holes on the passenger side are not threaded. only on the driver's side.
728673
Reply By: Member - Hillel K (VIC) - Tuesday, May 17, 2011 at 19:48
Try All Terrain 4X4 (03) 9532 5558 or www.allterrain4x4.com.au
454613
Reply By: Member - Desert Storm (QLD) - Sunday, May 29, 2011 at 00:07
