towing hitches - ORAC and/or TREG
Submitted: Friday, Mar 22, 2002 at 01:00
Fabian
Hi there,
I am looking for a local and reputable supplier in the ACT for ORAC or TREG hitches for my 4WD trailer, which currently has the standard towball arrangement. While this has worked
well so far (trip to Fraser Is, Lamington and
Barrington tops) I am planning to go on rougher tracks.
Any suggestions?
Also, any thoughts on pro/cons when choosing between ORAC and TREG?
Any reply would be much appreciated.
Fabian
Reply By: Peter - Friday, Mar 22, 2002 at 01:00
Fab,
Just to let you know there is an RAC off road hitch as
well whick is just as good and a lot cheaper too.
Pete
2480
Follow Up By: Fabian - Friday, Mar 22, 2002 at 01:00
Pete,
Could you pls provide or point to more info on the RAC hitch? Have never heard of this and would be interested following up.
Fabian
914
Follow Up By: Peter - Friday, Mar 22, 2002 at 01:00
Fab,
Other the other side they call it the NRMA. See them. They should be able to help you.
915
Fab,
Over the other side they call it the NRMA. See them. They should be able to help you.
916
Fab,
well which is just as good and a lot cheaper too.
Pete
2481
Reply By: Rob - Saturday, Mar 23, 2002 at 01:00
The main difference is that the orca is a true universal coupling with 360 degrees articulation in all directions.Have a look at the O'briens trailer site at
http://www.obrienstrailers.com.au/default.html The coupling is found in accessories.
The treg on the other hand has a limitation in the vertical movement of 23 degrees up or down. The treg can be viewed on the tregtrailers site at
http://www.tregtrailers.com.au/couplings.htm
I have had a treg for 9 years & have not had any trouble with it. Have dropped down some vertical
creek crossing at The Cape also.
If you contact the maker on his website I'm sure he will tell you were you can buy one in your area.
Rob
2490
Reply By: Bob - Monday, Mar 25, 2002 at 01:00
Resort Trailers of Queanbeyan
2500
