Cleaning Water Tank in Caravan
Submitted: Thursday, May 26, 2011 at 22:27
Member - Dunworkin (WA)
Hi All, have just checked the archives for this and found where vinegar has been used also bicarb of soda, Could someone please give me amounts to use? our
tank has got a bad taste in the
water and I feel a good clean could be in order.
Thanking you in advance.
Deanna
Reply By: wbsl - Friday, May 27, 2011 at 07:32
Hi Deanna
I use Miltons tablets, baby bottle cleaner.
Normally use about half strength of the directions on the packet, leave in for a few days and then flush out the
tank.
Regards Wayne
455589
Follow Up By: Member - Jack - Friday, May 27, 2011 at 07:46
I will second the
Milton. I have the liquid and works equally as
Jack
728497
Follow Up By: Member - Dunworkin (WA) - Saturday, May 28, 2011 at 02:05
Thanks wbsl & Jack for that, I hadn't heard of that one before but stands to reason that it should work.
728571
Follow Up By: Member - Jason B (NSW) - Sunday, May 29, 2011 at 22:24
3rd for the
Milton tablets. Just put them in and leave them for a few days. If you want you can go for a drive around the block to mix them up and also run the
water mix through all of your pipes and pumps. I keep my
water tank empty also if not being used for long periods.
Jas
728776
Follow Up By: Member - Dunworkin (WA) - Monday, May 30, 2011 at 00:25
Thank you Jason B, the
Milton tablets sound very popular.
D
728784
Reply By: Notso - Friday, May 27, 2011 at 07:57
If you want to try Bicarb, about 500grams dissolved in a bucket of
water, syphon or tip it into
tank, fill
tank to top, leave for a day or two, drain and flush
Tastes can be caused by using ordinary garden hose to fill
tank, always use food grade hose to fill
tank.
455590
Follow Up By: Member - Dunworkin (WA) - Saturday, May 28, 2011 at 02:13
Thanks for the measurements Notso, much appreciated.
728572
Reply By: snoopyone - Friday, May 27, 2011 at 08:40
Tankcleen form Caravan outlets does the job About $10- $15 a tin made for the job
455598
Follow Up By: Member - Dunworkin (WA) - Saturday, May 28, 2011 at 02:14
Thanks snoopyone, I think Camec might stock it, I've heard it is quite good.
728573
Reply By: V8 Troopie - Saturday, May 28, 2011 at 00:51
If you had filled the
tank from an unreliable
water source then 1ml of bleach to every 10 liters of
water will make it potable and that dose does not appear to affect the smell or taste.
I used that ratio on my boat on a 3 months
Kimberley cruise where the tanks were frequently topped up from waterfalls.
So, after you had cleaned your tanks - you could also use a stronger dose of bleach for this, which must be flushed out completely - an occasional dose as above will prevent any further problems.
BTW, my
water tanks are the rigid black poly caravan type.
455678
Follow Up By: Member - Dunworkin (WA) - Saturday, May 28, 2011 at 02:19
Thanks for the reply V8 Troopie, we have a
drinking water grade hose that we use to fill the van up, it's just been so long since it was cleaned and last time we took the van out I could taste the tainted
water, Hubby couldn't so it isn't too bad but still needs cleaning.
D
728574
Reply By: Graham & Ann - Sunday, May 29, 2011 at 18:22
Good place for info on cleaning
water and
water tanks is the B.E.S.T.
Water Filters web site. They have a pdf file re 'The method we recommend to clean tanks with 'questionable' quality or bacterial content. Safe and non-offensive solution!"
455813
Follow Up By: Member - Dunworkin (WA) - Sunday, May 29, 2011 at 18:59
Thanks for that Graham and Ann, sounds good, will check it out.
D.
728750
Reply By: landseka - Sunday, May 29, 2011 at 19:28
I second using bleach to clean a tainted
tank.
I don't believe the problem would be from filling with anything but "Food Grade" hose though.
I always fill my tanks at home with the garden hose as my Blue hose is not long enough and have never had a problem.
Saying that, I always, where possible use the blue hose when propped in a
park and have the van connected to a tap via the hose.
I don't doubt the
water could pick up a 'taste' when left sitting, under pressure in the hose perhaps in the sun too.
Cheers Neil
455818
Follow Up By: Member - Dunworkin (WA) - Sunday, May 29, 2011 at 19:55
Thanks for that landseka, bleach sounds good,
D
728756
