Battery Chargers
Submitted: Sunday, May 29, 2011 at 10:06
Member - Desert Storm (QLD)
Does anyone know if you can have your battery charger hooked up (say at a caravan
park) charging the CT battery while you still use it? Will the battery be getting its charge from the 240/12 volt charger while using the lights, running the fridge,
water pump, etc.
Reply By: Bigfish - Sunday, May 29, 2011 at 10:14
Have been doing it for years and no problems.
455757
Reply By: Member Al (Sunshine Coast) - Sunday, May 29, 2011 at 10:17
Its just like your bank account John.
How
well it gets topped up depends on how much you are putting in and how much you are taking out. The difference will be the contribution to your account, err, battery. It may go up or down.
But certainly there is no harm in drawing load from the battery whilst charging it.
455758
Reply By: kev.h - Sunday, May 29, 2011 at 10:20
Yes no problem I do it all the time. As long as the charger is hooked up to the battery it will be getting some charge ( what ever is left over after you run everything in the van ) assuming your charger has a higher capacity than what the van uses. You will have to add up the current draw the van requires to determine what size charger is needed
Cheers Kevin
455759
Reply By: Member - Bruce C (NSW) - Sunday, May 29, 2011 at 12:01
Hi John (desert Storm),
The best idea is to have a multi stage charger to do this because if you have not used much power and the battery is close to full and you go away for the day sight seeing you could overcharge the battery thereby shortening its life span. A good multi stage charger will avoid this and you can do it with peace of mind.
I have my CTEK connected continually when on the road so that as soon as I connect to shore power (caravan
park supply) I am charging the van batteries straight away.
This way the batteries are always topped right up for the free camps in between
park stays.
Cheers, Bruce.
455765
Reply By: Member - Desert Storm (QLD) - Sunday, May 29, 2011 at 16:17
Thanks guys, some good information there.
455788
Reply By: Ozhumvee - Sunday, May 29, 2011 at 17:46
I've just fitted a Projecta Intellicharger to do exactly what you have done.
Works
well, since fitting it the truck has been in the shed so it is keeping the batteries up whilst running fridge and lights as solar panels are covered.
I've had two Ctek smart chargers for years and they have both worked perfectly without problems. When I went looking for another charger to fit permanently I heard good reports about the latest Projecta's from both retailers and users.
They have a few advantages over the Ctek's, ability to select battery types, ability to select charge levels, remote head (this is a huge plus in a van or motorhome as the charger can be operated remotely without getting into battery compartments,
bins etc), plus they are slightly cheaper.
I've bought all three (2 Ctek's and the Projecta) from the one seller on ebay '4wdxtreme" no association with them, just a satisfied customer.
455805
