Finally, at last, about time - 80ch
The 80 ( 77) channel law came into effect on the 26th May.
http://www.comlaw.gov.au/Details/F2011L00862/Download]Amendment to UHF law
If you recently bought a UHF then you should be able to get an upgrade to 77channels.
If you buy a UHF that is 40 channels only, you'ld want to make sure it is dammed cheap. It will be illegal to use in 5 years.
Reply By: jdpatrol - Monday, May 30, 2011 at 08:58
Bookbook, link got mucked up a bit, try this:
New 80 Ch Legislation details
AnswerID: 455857
Follow Up By: Member - Boobook - Monday, May 30, 2011 at 10:53
Thanks jd patrol
FollowupID: 728804
Reply By: olcoolone - Monday, May 30, 2011 at 09:15
The law isn't finalised yet, it got government gazetted on the 25 of May meaning it's in it's final phase of becoming law.
I haven't been able to find what date it is meant to come into law.
AnswerID: 455862
Follow Up By: Member - Fred B (NT) - Monday, May 30, 2011 at 09:42
Gooday olcoolone,
The documentation clearly states it comes into effect the day it is published in the gazette (as does all legislation unless a specific rider is attached).
regards
Fred B
VKS 737: Mobile/Selcall 1334
FollowupID: 728798
Follow Up By: Member - Boobook - Monday, May 30, 2011 at 10:54
Yep it is law alright. Done and dusted. There is also a similar amendment about the specs of the equipment. ( it's law too)
FollowupID: 728805
Reply By: Member - Captain (WA) - Monday, May 30, 2011 at 10:07
More channels is good, can get pretty crowded at times. But I cannot see how the ban on 40 channel (25mHz spacing) will happen. There are literally 1000's upon 1000's of the cheap 40 channel handhelds that every kid has, never mind the more expensive in-vehicle units - there is no way they will simply end up in the bin. I still have my UHF handheld from when I was a kid, thats gotta be 30++ years old and still going strong.
I have never had my two-way checked or inspected and without some form of enforcement or buy-back plan, the 40 channel will stay in circulation for ever IMHO. Banning 40 channel (25mHz) sounds like a practical idea only if you sit on a chair in Canberra!
Captain
AnswerID: 455869
Follow Up By: Member - Andrew L (QLD) - Monday, May 30, 2011 at 10:14
Agreed on the probable inability of government/regulators to have the gonads and resources and will to remove the 25mHz units out there that would be unable to be reconfigured.
Should also be more interesting out there with the amatuer CB'er's who have needed to upgrade their power outputs to say 25 watts to get their voices and messages shouted out into the stratosphere, while drowning out the legitimate 5 watt users for tens and tens of kilometres.
FollowupID: 728800
Reply By: Michael ( Moss Vale NSW) - Monday, May 30, 2011 at 16:15
So can someone shed some light why we apparently needed 80 channels? Dont tell me the Federal Government was thinking of its UHF radio users. It can only be in the interest of the Feds themselves and obviously the radio makers are in for a windfall having to replace all those obsolete radios.. Michael!!!
AnswerID: 455902
Follow Up By: Member - Boobook - Monday, May 30, 2011 at 16:23
If you don't need it then don't get it. Simple. \
Others DO have issues with crowded channels which this goes some way to resolve.
There are no extra fees so how can you think the government is in the interests of the Feds as you say.
FollowupID: 728846
Follow Up By: Michael ( Moss Vale NSW) - Monday, May 30, 2011 at 16:31
I think you missed my question!! Michael
FollowupID: 728847
Follow Up By: Member - Boobook - Monday, May 30, 2011 at 16:50
Sorry Michael
The only question I can find in your post is
"So can someone shed some light why we apparently needed 80 channels?"
And to be clear, my answer to that was
"If you don't need it then don't get it. Simple. \
Others DO have issues with crowded channels which this goes some way to resolve."
What was the other question that I missed? Try as I may, I can't find any others.
FollowupID: 728849
Follow Up By: Michael ( Moss Vale NSW) - Monday, May 30, 2011 at 16:57
Boobook, i just read the intro of the Legislation.. Apparently the changes are primarily for extra channels.. Surprises me somewhat... considering govts dont really do too much for the common man!! Michael
FollowupID: 728851
Follow Up By: Life Member - esarby (NSW) - Monday, May 30, 2011 at 17:05
I am just a layman as far as the 40/80 channels go. As I understand it, we now have 40 channels spacing at 25 K khz. in the same area of the spectrum we now have 80 (77) channels spaced at 12.5 Khz. The new 40 channels will be 1A, 2A, 3A, up to 40 A. will not the original 40 channels still be in the same place? So my 40 channels will still be in the same place 1, 2, 3, - - - - - 40. As I said, I am a layman as far as this electricary goes and am willing to be enlightened. Sounds to me like another Government grab for cash. Steve.
FollowupID: 728852
Follow Up By: Member - Tezza Qld - Monday, May 30, 2011 at 17:50
I think it is more about moving voice communications to the narrow band width.
Apparently narrow band is clearer for voice transmissions The current wider band is better suited for data communications. The extra channels are just a bonus as cb uhf will still operate from 476.425 mhz to 477.400mhz only with 12.5 channel spacings instead of the current 25.
Just my thoughts and happy to be corrected.
Cheers Teza
FollowupID: 728858
Follow Up By: Member - Boobook - Monday, May 30, 2011 at 18:16
Ok I'll see if I can explain the changes.
There is a band of UHF spectrum allocated to CB unlicenced use. It was 476.425 Mhz ( CH 1) to 477.4 MHz ( Ch 40). At the time it came out 15 or so years ago 25 KHZ ( or 0.25 MHZ) spacing was about as good as cheaply priced equipment could get, divide the differnece by 25khz and you get 40 channels.
As time has moved on, so has technology. Now radios can easily work at 12.5Khz, known as narrow band in this context, as well as the 25khz at reasonable cost. Even 6.25 or less is available for some commercial radios.
So the ACMA, the government authority responsible for this stuff has said that by using the narower 12.5khz channel width, 80 channels can be accommodated in the same spectrum space as the old 40, hence this change.
So the exiisting 40 channels stay in the same spot, but are now narrower, and only use half the space in between. That creates space for the channels 41 to 80 halfway between each of the channels.
So in terms of frequency use it now goes
CH1
Ch41
Ch2
Ch42
Ch39
Ch79
Ch40
Ch80
But the new radios are set up so you see it as 1 - 80. So the new channels 1 - 40 are in the same spot as the old 40 channels. The new channels 41 - 80 are half way in between.
It's a bit like a bench with 40 people sitting on it and someone says "pull in your gut and let a new person sit in between each of you". The bench is the same width but it now takes 80 people, but they all have to be skinnier.
In addition ACMA are aware that some channels are important and may not interoperate with the standard properly given that it is old equipment. Specifically this is the old Channels 5, 22 and 23. So the new adjacent channels 45, 62, and 63 are not able to be used ( at least for a while anyway) to protect these services of emergency repeaters, and data. Thats why it is 77 channels not 80 in reality.
So now there are people using equipment with either 40 wide channels, or 80 narrow channels, for the main part they are interoperable but there are small incompatibilities. So ACMA in their wisdom said you can use either but the old system has to go by 2016 ( from memory).
Hope this makes sense.
FollowupID: 728860
Follow Up By: pop2jocem - Monday, May 30, 2011 at 18:42
Hi Boobook,
Your explanation was so simple yet clear that even an electronic dummy like me got a pretty good handle on it (I think).
If I may could I ask what no doubt will seem a somewhat dumb further question. So 4 UHF sets operating within range of each other, two are the older 40 channel jobbies and the other two the new beaut 80 channel ones.
If the 2 new ones are talking to each other and the 2 old ones are talking to each other how would they affect each user if for example the 40 channel sets are on say ch 18 and the new ones are on an adjacent new channel.
I hope you can understand my ramblings.... after reading that lot I'm not sure even I do.....lol..... but I can't think of any other way to ask it.
Pop
FollowupID: 728863
Follow Up By: Member - Boobook - Monday, May 30, 2011 at 19:29
Pop, firstly if they are 80ch or 40 channel units, and they are all on channel 18 then they will all be able to talk to each other. Then if as you say the oldies are on channel 18 and the new ones nearby are talking to each other on say Channel 67 or 68 which are the next adjacent channels down and up from 18, then there will generally be no interference unless they are very close, then you could get some crosstalk, in other words you might hear some distorted sounds, a bit like a distant hard to hear signal. In fact you hit the nail on the head as to why channels 45, 62 and 63 have been delayed. These are called "guard channels" as they provide a guard or buffer so this doesn't happen at all on channels 5, 22, 23.
*most* of the time it should be ok in practical situations though. It is a bit like 2 radio stations clashing if they are close in frequency. Generally there is no problem but sometimes if there are two distant stations that are close in frequency you get crosstalk, same principle.
I am not sure how bad it will be in practice, but you would hope our beloved communications authority did some testing and have some experience....
FollowupID: 728872
Follow Up By: Darrynrj - Monday, May 30, 2011 at 19:35
Australia's UHF CB system came into operation in 1978/79 and was supposed to replace the 27 mhz by 1982. The removal of the 27 mhz system was realised to be virtually impossible for the same reasons that finally allowed for legalisation of the 27 mhz system in 1977 - the sheer volume of radios in use. I can't see too many people giving up the old 40 ch UHF's for the same reason and there is no way Spectrum Management Australia could enforce it.
Cheers Darryn
FollowupID: 728873
Follow Up By: pop2jocem - Monday, May 30, 2011 at 20:00
Thanks Boobook, I think I have a better handle on it now
Pop
FollowupID: 728876
Follow Up By: River Swaggie - Monday, May 30, 2011 at 22:24
"It's a bit like a bench with 40 people sitting on it and someone says "pull in your gut and let a new person sit in between each of you"."
Picking on the poor ol Fat man once again....lmao
FollowupID: 728892
Follow Up By: UHF CB Australia - Tuesday, May 31, 2011 at 01:28
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
FollowupID: 728907
Reply By: eighty matey - Monday, May 30, 2011 at 20:44
Thanks very much for the clear explanation Boobook.
Many people might be attached to their 40 channel radios at the moment but I reckon nearly everyone will move to the 80 channel sets soon enough.
I remember when the AM sets were made virtually obsloete overnight when the trucks took to the UHF radios. Nearly everyone switched over and it pretty painless.
eighty matey
AnswerID: 455924
Follow Up By: Member - Boobook - Monday, May 30, 2011 at 20:59
eighty matey replied:
... I reckon nearly everyone will move to the 80 channel sets soon enough.
I hope not eightly matey. The less the better. Especially the suburban hoon / sewaring brigade. Let 'em stay on the bottom 40 channels I say. That's the main reason I am interested in 80 channels personally speaking.
FollowupID: 728884
Follow Up By: eighty matey - Monday, May 30, 2011 at 22:55
I have to upgrade. My set has started to get unreliable at times and that doesn't suit me.
I guess we'll find the idiots that need to bag out truck drivers to get their jollys, or tell how to make the perfect cup of coffee (constantly) will change to maintain their audience.
It's time for a change. I'll accept it.
eighty matey.
FollowupID: 728899
Reply By: Roachie.kadina.sa.au - Monday, May 30, 2011 at 20:54
So, can somebody enlighten me please.... I recently bought/installed a new GME 3340 (or maybe it's a 3440??, not sure...it has the controls all located in the microphone).
The blurb that accompanied it said it had an extra 40 channels which are "user programmable".
Does that mean I effectively have the right set to see me into the foreseeable future?
Roachie
AnswerID: 455925
Follow Up By: MEMBER - Darian, SA - Monday, May 30, 2011 at 22:24
Seems the 3440's shipping now are upgradeable to the 80 channel spec (with the factory software provided to dealers) - but more $$$ of course :-o)..... They have 57 extra RECEIVE ONLY channel slots too that can be user programmed (questionable value for most, I expect). The new spec has virtually killed off any market for used UHF's anyway - wait and see is my stance - my 40's might still see me out :-o).
FollowupID: 728893
Follow Up By: MEMBER - Darian, SA - Monday, May 30, 2011 at 22:30
Oh.... and ..... UHFcb.com.au is useful.
FollowupID: 728895
Reply By: Member - Joe n Mel n kids (FNQ - Monday, May 30, 2011 at 21:09
that is a good explaination of it as i have wondered for some time how it worked so now i know.................
But i do have to ask ??? i admit i live way out in the bush and stay well away from any citys but i do have to go to them from time to time and i have the UHF on and i have had it on "scan" and i can not remember it being cluttered ....
Do i maybe have just the standard antenna that does not pick it all up.. just maybe ???
Or are we asking to much from a system that was designed for short distance comms, they were not supposed to be for long distance and some i think even had a switch to reduce the output wattage so it was kept "short distance" to avoid clutter ........... so if we have trimmed it up to get max distance from it and now are finding it cluttered with 40 channels well guess what folks, 77 channels is NOT going to solve any problems, and i know many people will disagree but just give it 2 years and tell me it worked ..... yep i will probally buy one, just because it has 77 ch, and only a handfull that i need but at least i will have one hahaha (boys and there toys !!)
Joe
AnswerID: 455928
Reply By: Shaker - Tuesday, May 31, 2011 at 09:19
So that means another 40 channels for the bogans to abuse with foul language & inane chatter.
AnswerID: 455962
Reply By: geocacher (djcache) - Friday, Jun 03, 2011 at 09:24
Well it's not often I have a win, but I just looked at the specs & my good old Icom 400 has a narrow band spec so I should be able to reprogram it.
As luck seems to be an infrequent experience I guess my Tatt's numbers won't come up this week, but I have saved on a new UHF...
DJ
AnswerID: 456228
Follow Up By: Member - Boobook - Friday, Jun 03, 2011 at 10:04
Not only that DJ, but if you join this forum, someone has done the hard work for you.
Yahoo IC400 group
FollowupID: 729248
Follow Up By: garrycol - Friday, Jun 03, 2011 at 10:27
Though the Icom 440 cannot be upgraded and at this stage Icom are not releasing a 80 channel version of it.
Garry
FollowupID: 729254
