Indicators not working
Submitted: Monday, May 30, 2011 at 08:19
ThreadID: 86637 Views:1988 Replies:2 FollowUps:0
Over the weekend I pulled the dashboard section of my 08 To Patrol apart so that I could access the rear of the Pioneer stereo I have installed, as well as the speaker for the sat nav unit which us cactus. When I have tried to replug everything, the indicators no longer work. I have checked the fuse under the dash and it is fine. Also, the Hazard lights work, although I had originally unplugged the switch along with the rear demister switch. I have removed the double DIN radio and UHF, and reinstalled. Everything I can see or have touched are just plugs, with the exception of what looks like 3 earth wires connected to the bottom right screw if the stereo DIN mount. 2 of these wires are for the stereo and UHF, but there is a third I am not shore of what it is for. It does look like it is an original factory wire, not any of the accessiries Installed. Any suggestions of where to look to get the Indicators working again?
Reply By: toohey - Monday, May 30, 2011 at 15:08
g'day
the blinkers are on a diferent fuse to the hazards?????
cheers toohey
AnswerID: 455897
Reply By: wjh41 - Monday, May 30, 2011 at 20:24
Hello Patrol GU V1,The blinkers on my 04 stopped working and it was a fuse under the bonnet on the drivers side,check them out. Wally
AnswerID: 455921
